Ignitor Sparks Through Complete Cycle. Carrier 58GS - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2009, 04:57 PM   #1
Ignitor sparks through complete cycle. Carrier 58GS
I'm having a hard time determining why my ignitor is sparking thoughout the complete heating cycle. Hoping someone can help.
My furnace is a Carrier 58gs model. Here's a scan of it's wiring diagram....
If you look at the gas valve in the diagram, there's a hold switch between terminals 4 & 5 on the gas valve. Apparently this connection is held until the main gas burners come on. Well, I constantly have 24v to terminal 5 instead of it shutting off after the main gas valve opens. I ended up replacing the gas valve assembly and the new one is doing the exact same thing! Am I missing something here?
I've also replaced the 3-wire pilot assembly, and it's working as it should.
slick-rides is offline   Reply With Quote
Old 12-21-2009, 06:57 PM   #2
Ya but is the little sensor neww/the orange wire going to it.Pick and hold coil in that valve...clean or replace little square porcelin sensor
hf05 is offline   Reply With Quote
Old 12-21-2009, 07:11 PM   #3
Which sensor are you asking about?
This gas valve doesn't have a pick and hold coil. Instead it uses a pressure switch. Once the heat sensor from the pilot turns on the main gas valve, the pressure from the main gas flow is supposed to open the switch.
Old 12-21-2009, 09:32 PM   #4
3 wire pilot. grenn,yellow and white?.if so u have a spark electrode and if u changed this u would know what i mean !
Old 12-21-2009, 10:48 PM   #5
So you're saying the spark electrode itself has a sensor in it? That doesn't seem right. I removed the electrode from the old pilot and transfered it to the new since it was sparking fine.
Old 12-21-2009, 11:47 PM   #6
they yanked response...
Old 12-22-2009, 05:57 PM   #7
HVAC Tech/ Browns Fan
Ok is the pilot a long metal ( bi Metal) It has yellow, green and white wire going to it. If so you need to clean the inside metal were the flame hit it. You should not need to replace it just clean it. Please if anything take a pic of it ( pilot)
Tator1076 is offline   Reply With Quote
Old 12-22-2009, 06:28 PM   #8
Yes, it's the 3-wire(G,W,Y) pilot. I've already replaced it because it wasn't working before. I even tested the circuit with jumpers to make sure the pilot wasn't my problem. I did this by disconnecting the 3 wire plug coming from the pilot. I then jumpered what would be the green and yellow wire terminals, pilot and igniter comes on. I then moved the jumper to the white and yellow and the main gas burner comes on, but the igniter continues to spark.
If I disconnect the wire from terminal 5 on the gas valve, the ignitor stops. I have a constant 27v at terminal 5, when it should be switched off.
If you need any more info or want me to check something else, let me know.
Old 12-22-2009, 06:43 PM   #9
Ignitor is part # LH680005 and gas valve is part # EF32CW183.
Old 12-22-2009, 06:46 PM   #10
Ok check and see if the pilot is rolling. If it is you may have a crack near that piloit when the fan hits it.
Old 12-22-2009, 06:48 PM   #11
Note you may check the pig tail in sure its has a good conection together. You can do it when heat is calling
Old 12-22-2009, 06:52 PM   #12
Looks fine to me. I just tried to take a couple pics and a short video. Give me a minute and I'll post them up.
Old 12-22-2009, 06:56 PM   #13
gave me a pic of pressure switch too
Old 12-22-2009, 07:01 PM   #14
Pressure switch is inside the main gas valve as pictured above. The switch is between terminals 4 & 5, with 5 being the one going to the ignitor.
Video will be on youtube in 2 min.
Old 12-22-2009, 07:02 PM   #15
MXer
3 legged dog's Avatar
Sounds like something wrong with spark electrode.
Could also be a bad ground.
3 legged dog is offline   Reply With Quote
