#1 |
Ignitor Problem Carrier
Hello,
I have a Carrier 58GSC045 Furnace. The unit starts up the pilot correctly, when the burners fire up the ignitor keeps on ticking. Any idea what might be causing the problem. Thanks |
#2 |
Hvac Pro
I believe that unit has the old mechanical warp switch pilot burner. Notorious for failing/sticking when they get old and are quite an expensive part. I would start considering a new furnace as that one is getting pretty old. The heat exchanger may fail soon.
#3 |
I just replaced the pilot burner/ignitor assembly. The furnance is about 17 years old but has not been used much since I live in S. California- typically 30 days each year.
Thanks |
#4 |
Hvac Pro
Hang in there, we have some more experienced Carrier guys here. Those units are mostly obsolete where I am. Used 200 days of the year. Just like your A/C units.
#5 |
burner will not light
#6 |
Professional
the 3 wire pilot assembly is going bad, that is causing the ignitor to continue sparking
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Carrier 58 RAV Error 33 | packmanMRP | HVAC | 9 | 11-24-2008 03:15 PM |
| Carrier rep coming to diagnose a problem | Faulknertw | HVAC | 14 | 07-17-2008 12:25 AM |
