Ignitor Lights, Can Hear Gas, Furnace Doesn't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 08:08 AM   #1
Ignitor lights, can hear gas, furnace doesn't light
I have a Goodman GMT070 gas furnace with an electronic igniter. It stopped lighting and I noticed the igniter was not glowing, so I replaced the igniter with a Honeywell universal igniter from Home Depot. Now, the blower comes on, the igniter lights up, the gas valve clicks once, and I can hear the gas jet for about 4 seconds, but the furnace doesn't light. The control board repeats this sequence 3 times before giving up and going into a wait period.
I don't smell any gas, so I'm suspecting the gas control valve. The switch on the valve is in the "on" position.
Thanks,
Pede88 is offline   Reply With Quote
Old 02-05-2012, 08:13 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,136
the igniter is either shorter than the OEM one or not in the exact position in the jet stream to lite the gas.
Old 02-05-2012, 09:02 AM   #3
That was it! I had previously tried moving it side to side to get it in the jet. I needed to use the angle bracket that came with the Honeywell replacement igniter to lower it about an inch.
thanks
Old 02-05-2012, 09:04 AM   #4
Hvac Pro
yuri's Avatar
yer welcome. now remove and clean the flame sensor that sits in front of the other burner with #800 emery cloth or fine clean steel wool. looks like this.
American Standard furnace - burner won't light byoung309 Appliances 4 12-29-2011 01:24 AM
Furnace pilot light will not ignite - Carrier 58 GS Furnace? rasilun HVAC 3 10-29-2011 10:38 PM
Furnace will light - if I hit it! Chuch HVAC 1 10-28-2011 03:05 PM
Bryant furnace won't light, not HSI amylynn6 HVAC 8 11-01-2010 11:07 AM
Carrier Furnace Series 160 Pilot Light issue eastons HVAC 2 03-15-2009 03:26 PM
