Ignitor Glows, No Flame - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 11:01 PM   #1
boweb616
ignitor glows, no flame
Hello , have a tech 4 true blue 90 furnance. When calling for heat blower motor starts then ignitor glows, do not here any clicks, no flame. Will cycle again and same thing. Checked vent , its clear. The green light is a constant glow no flashing. Ideas??? Its cold here in Michigan. Thanks boweb6
boweb6 is offline   Reply With Quote
Old 12-05-2009, 11:19 PM   #2
HvacWiz's Avatar
Rewards Points: 252
Sounds like a bad gas valve, the tech 4 furnace has a honeywell smart valve on it. these valves are famous for going out.
HvacWiz is offline   Reply With Quote
Old 12-06-2009, 12:24 AM   #3
Try wiggling the wires going into the gas valve. Sometimes you can get that smartvalve to work for a little while that way. Replace it ASAP. Get all the numbers off of the label on the valve because there's several of them and they are not interchangeable.
Old 12-07-2009, 11:15 AM   #4
boweb616
Originally Posted by hvacwiz View Post
sounds like a bad gas valve, the tech 4 furnace has a honeywell smart valve on it. These valves are famous for going out.
ok thank you very much. I am north west ohio also. How does one check for a bad gas valve??? WHEN I TURN THE SWITCH OFF AND ON I HERE A CLICKING SOUND. IS THIS USUAL? THANKS
Old 12-07-2009, 02:09 PM   #5
An old Tradesmen
Rewards Points: 6,086
Please don't make duplicate threads/post of the same problem. i got rid of your other one.
Thank you.
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 01:36 PM
York Diamond 80 Intermitten Flame Setdyi HVAC 38 02-08-2014 01:20 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 09:19 AM
Gas Fireplace Pilot Flame MicRos HVAC 2 11-01-2009 07:15 AM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 11:30 AM
