Ignitor Condition - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2009, 08:08 AM   #1
Ignitor Condition
I was just told that the ignitor on my gas furnace (a RUUD 15 yrs old) is "on its last leg". Is there something to look for or a way to tell if this is the case?
The ignitor functions, has a dark "spot" near the center of it (is this common to aging or something else?) and that area glows brighter when the ignitor turns on.
Thanks for helping me understand the recommendation to replace the ignitor. [The repair looks straight forward, turn off power; remove 1 mounting screw and electrical connector then reverse for installation of new ignitor.]
DIYNew is offline   Reply With Quote
Old 10-22-2009, 05:26 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,120
It IS on its last leg. That bright spot will overheat and burnout very soon. After seeing hundreds of them burn out a tech knows what to look for.
Old 10-23-2009, 06:04 AM   #3
An old Tradesmen
Rewards Points: 6,112
Yep.
Common to find that on a clean and check.
Those customers that have them replaced right away. Have heat all winter long(providing other failures don't occur).
Those that don't. usually end up with no heat in the middle of the night, or on a weekend or holiday.
Old 10-23-2009, 11:08 AM   #4
Thanks for the advise. I'm ordering 2 today, 1 replacement, 1 backup. ... The replacing the ignitor looks straight forward. ... You were a great help.
