Ignition Problems Ongas Boiler For Steam System - HVAC - DIY Chatroom Home Improvement Forum
Old 11-12-2008, 12:49 PM   #1
Ignition problems ongas boiler for steam system
I have a gas boiler for a steam heating system.
The ignition is going off every 30 secs or so (and sometimes igniting for a second or two) when the temperature is set below room temperature. Othersise OK to heat normally (when set above room temp).
Any suggestions?
Thanks,
Nick
NickG is offline   Reply With Quote
Old 11-12-2008, 01:00 PM   #2
disco the tstat wires and see if it stops if so the tstat if freakin out
kennzz05 is offline   Reply With Quote
This may help someone with carrier ignition problems AweMan HVAC 15 02-09-2009 01:20 PM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
Steam heating system problems Need HELP smay0808 Plumbing 7 11-05-2007 11:17 PM
Weil Mclain Boiler air in system manning01 HVAC 11 10-06-2007 10:35 PM
Problems with Central Air Cooling System golfgod04 HVAC 4 05-27-2007 08:51 PM
