Ignition Control For A Snyder General Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 07:12 PM   #1
ignition control for a snyder general furnace
I have a snyder general furnace mdl GUD040A012-IN, S/N 0000247276-N15-0007. I was told I needed to replace the ignition control. I tried to order it online but they need the part number. How does it look like or where can I find it on the furnace so I can get the part number?
Thank you.
junjuguilon is offline   Reply With Quote
Old 03-22-2013, 12:57 AM   #2
REP
There should be a part number on the control itself along with the name of the manufacturer.
REP is offline   Reply With Quote
Old 03-22-2013, 12:35 PM   #3
snyder general ignition control
Good morning,
Thank you for your reply. Would you mind telling me where would this control be located inside the heater so I can find the part number and the maufacturer or perhaps, give me an example of a part number of this a control of the same type so I can look for a similar number.
I do apologize since I am not familiar with heaters and ignition controls.
Thank you again.
Old 03-22-2013, 01:55 PM   #4
Originally Posted by junjuguilon View Post
Good morning,
Thank you again.
Take the cover off your furnace & take a picture & post it here. That will make it a lot easier for someone to tell you which part it is.
JScotty is offline   Reply With Quote
Old 03-23-2013, 04:59 AM   #5
biggles's Avatar
looks like these
mounted on the fan housing or in front of the burners http://www.bestbuyheatingandaircondi...ry_Code=cb-icp
Old 03-23-2013, 11:11 AM   #6
That vintage might need the Fenwel control.
hvac5646 is offline   Reply With Quote
Blower won't stop after replacement of ignition control module jhevelone HVAC 2 02-17-2013 06:11 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Carrier Gas Furnace - Problems with Ignition jean004 HVAC 33 01-17-2012 02:26 AM
Problem with old Rheem furnace ignition Troublefix HVAC 7 02-02-2011 04:52 PM
Snyder General Gas Furnace - No Gas to the ignitor Hanela HVAC 5 12-04-2006 12:37 PM
