Old 12-20-2012, 06:41 PM   #1
ignition control module or spark ignitor issue?
SnyderGeneral furnace Honeywell control board.
Is it as likely a spark ignitor board would go out as the actual spark ignitor? Is it worth replacing instead of the ignitor itself? I can replace the board easily..not sure about the ignitor itself as it is inside the unit.
S8600H Honeywell board
agent86 is offline   Reply With Quote
Old 12-20-2012, 06:49 PM   #2
replace the part that is not working..... both if yo want... its your money..
carmon is offline   Reply With Quote
Old 12-20-2012, 09:03 PM   #3
thats called parts changing....not troubleshooting, you want to find out why and what part failed by tracing out wiring of system to the point of failure.....yes it could be ignitor..or board.or ground.or loose wire.or safety switch..or you get the point it could be alot of things...called troubleshooting..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
carmon (12-21-2012)
Honeywell Oil Ignition Control garpox HVAC 4 12-30-2009 08:40 PM
white rogers ignition control Davidj0717 HVAC 16 10-17-2009 12:25 AM
DIY recommendation for Goodman Control Module (Circuit Board) njwaves HVAC 3 09-26-2009 08:29 AM
Carrier ECM motor number pwrengineer HVAC 19 06-22-2009 02:21 PM
furnace ignition troubleshooting buju HVAC 22 01-14-2009 11:41 PM
