-   -   ignition control module or spark ignitor issue? (http://www.diychatroom.com/f17/ignition-control-module-spark-ignitor-issue-167019/)
agent86 12-20-2012 06:41 PM
SnyderGeneral furnace Honeywell control board.
Is it as likely a spark ignitor board would go out as the actual spark ignitor? Is it worth replacing instead of the ignitor itself? I can replace the board easily..not sure about the ignitor itself as it is inside the unit.
S8600H Honeywell board
carmon 12-20-2012 06:49 PM
replace the part that is not working..... both if yo want... its your money..:eek:
ben's plumbing 12-20-2012 09:03 PM
thats called parts changing....not troubleshooting, you want to find out why and what part failed by tracing out wiring of system to the point of failure.....yes it could be ignitor..or board.or ground.or loose wire.or safety switch..or you get the point it could be alot of things...called troubleshooting..ben sr
