Igniting Armstrong Ultra V 80 - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 01:34 PM   #1
How do you ignite the Armstrong Ultra V 80 Heater. It is perfect and has no problem. Every thing is in place except the electric plug is not plugged
Spartacus is offline   Reply With Quote
Old 07-27-2009, 04:41 PM   #2
You need to make sure the furnace is vented properly. Also need to make sure the furnace is designed to burn the fuel you intend to use. Other than that you will want to check the incoming pressure and after start-up you will need to check the manifold pressure and temp rise.
SKIP4661 is offline   Reply With Quote
Old 07-27-2009, 08:33 PM   #3
Araa malaka Spartakus!
hvaclover is offline   Reply With Quote
Can I glue down an Armstrong locking hardwood floor? Fixitgeorge Flooring 10 01-30-2013 11:49 AM
Behr Premium Plus Ultra beachnik Painting 2 06-15-2009 04:36 AM
Armstrong Ultra 5 Tech 80 furnace rusty427 HVAC 1 12-24-2008 08:33 AM
armstrong air ultra v tech 80 furnace model C2E24A-1A Iowachick HVAC 1 11-29-2008 06:15 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
