Igniter Silicon Nitride Testing - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 09:31 PM   #1
JJboy's Avatar
Igniter Silicon Nitride testing
Do you guys know if ALL Igniter Silicon Nitride operates with 70 ~ 80V or there are some models that operate with 120V like the Silicon Carbide? Also the resistance is around 11 - 17ohms.
I'm asking this because I'm working on a Goodman GMVC080 and the igniter glow but the burners doesn't light. The controller board is send 120V and the gas valve is open normally. The resistance on the igniter is 50ohms. I replaced with one igniter that has 15ohms and the furnace back to work.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-28-2012, 09:51 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
There are some models that do work with 120V. There are a number of carbide replacement nitride ignitors that work with 120V. For Example: http://www.forwardthinking.honeywell.com/related_links/combustion/glowfly/67-7316_Glowfly_Brochure.pdf
or
http://www.alpinehomeair.com/related...2_Brochure.pdf
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
JJboy (10-28-2012)
Old 10-28-2012, 09:52 PM   #3
Not all of them do JJ. Lennox surelite for example starts with over 100v on the first fire then drops the voltage 2-3% on each fire after that until it won't light then it bumps it up to the next step. After 5000 ignitions it starts the sequence all over. The resistance runs 15-19 ohms on those.
The Following User Says Thank You to Marty S. For This Useful Post:
JJboy (10-28-2012)
Gas Pressure Testing With Manometer a_lost_shadow Plumbing 4 07-01-2012 04:36 PM
silicon and mirror Andy21 Painting 5 02-23-2012 04:55 PM
Rheem No 120VAC Igniter Help Benihana HVAC 5 01-04-2010 03:39 AM
testing igniter sjay Appliances 1 07-12-2009 06:29 PM
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 10:55 AM
