Identifying Proper Rotation Of Squirrel Cage Wheel - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 06:31 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
NASA?
always wanted to see the equipment in mines and mills and we have lots up North here and in Ontario etc. Friend of mine was in Thompson/ INCO but I did not get up there in time.
Had a 200 hp 3 ph motor with Star Delta starter on a blower for a office tower. wheel was 10 ft in diameter and had 20 ft long belts. scared the heck out of yah when that starter was not setup properly. and a 1000 ton centrivac chiller. lots of interesting stuff mankind has invented.
the good ole days, strong like bull, removed lots of boilers, oil tanks, cast iron heat exchangers from oil furnaces in war time homes. now I just use the ole brain instead.
Old 07-02-2013, 06:35 PM   #17
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Justplum...thanks for suggesting I look closer.....I saw the first animation...in the link and stopped there...but when you read down further....you find the description of the 3 types...
Learn something every day...
I stand corrected............
And Yuri...not NASA....that is the tool for the Boeing 787 front fuselage...
That autoclave is 30' in dia....the door weighs about 40 tons...
Old 07-02-2013, 07:26 PM   #18
biggles's Avatar
if the filter gets saturated the squirrel is next then the coil...major bucks and forget the operation it is shot all of these dirt catches cause icing..right out to the compressor....
Old 07-02-2013, 07:43 PM   #19
Rewards Points: 1,596
Luv those pics ddawg, yepper.
Thx biggles- is that a residential blower wheel? If so, do you know how long it took to get that way?
justplumducky is offline   Reply With Quote
Old 07-03-2013, 09:13 AM   #20
biggles's Avatar
that could be a year or so with pets and carpets in the house the coil was packed above the fan section ....large tonnage residential unit.the real kick in the buuutt... is if the A coil is dripping water right on top of a heat exchanger with a furnace and A coil system air handler.that heat EX will rot out in one summer season,and leak carbon monox into the space in the winter...
Old 07-03-2013, 11:24 AM   #21
Sounds like a very expensive (not to mention dangerous) kick in the butt! Thx for that tip (and pic).
Old 07-04-2013, 08:01 AM   #22
PoleCat's Avatar
Rewards Points: 1,646
I have reinstalled a few cages backwards in my time and they still blow air, just not as much. After a couple of times you make a better effort to pay attention to what you are doing.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
grenaded squirrel cage raylo32 HVAC 10 01-17-2012 11:30 PM
Blower wheel vibration Knipper64 HVAC 1 11-10-2011 08:38 PM
Help wiring squirrel cage fan qoncept HVAC 2 07-14-2011 08:22 AM
Blower squirrel cage Dbenzboy HVAC 4 08-27-2010 08:05 PM
Squirrel cage motor in air handler...no start andyinrichmond HVAC 13 03-15-2009 03:53 PM
