Ideas For Anchoring Condensor Unit - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 09:59 AM   #16
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by COLDIRON View Post
Don't use that strapping it looks like crap, you wouldn't like the look and you will have to drill into your house. Have never seen anything like that in the field. If you really think you have to anchor it down you can go right through the inside of the unit down through the 4 legs into the concrete pad after the pad is changed and the unit is back level and in place. You really shouldn't have to anchor it.
In other words,
Hire a HVAC guy to do it and not do it yourself.
Replacing the pad would require disconnecting the unit.
So spend 500 for the pad or 20 bucks on some strapping.
sublime2 is offline   Reply With Quote
Old 12-09-2012, 11:07 AM   #17
A "HVAC guy" did this in the first place. I'm going to fix it.
Originally Posted by sublime2 View Post
In other words,
jfls49 is offline   Reply With Quote
Old 12-09-2012, 11:27 AM   #18
Roofmaster
Rewards Points: 2,210
Concrete
Buy some 2 x 10's form around the whole thing, Pin the ouside with 2x2 stakes and level the box. Buy Sacrete, and mix in a wheelbarrow and pour a slab under it right up to the bottom of the condenser. This is going to sound funny, but if you have a vibrating massager, hold it against the sides of the form so it vibrates the concrete. This will remove air pockets against the form. use an edger around the slab to relieve the edge while the concrete is wet. If the concrete shrinks away from under the unit, just slide some Galvanized shims under the unit.
Whoever mounted your unit like that is............ well, "If you cant say anything nice, dont say anything at all"
Thumpers Mom
Old 12-09-2012, 12:32 PM   #19
Please explain how I mudjack under this pad?
Originally Posted by Fairview View Post
Level the pad and mud jack until all the cavity underneath the plastic is full.
Old 12-09-2012, 12:41 PM   #20
I'm Your Huckleberry
Rewards Points: 2,270
Not unless you have all the hvac tools to properly do it you're not. The true and proper way to do it is to remove/disconnect the unit and move it aside. Other than that you can pry up the unit and set bricks or dirt under there but without a build up and hard pack of the dirt you'll still be playing Russian Roulette.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-09-2012, 12:43 PM   #21
In other words,
An Ultra Lite pad doesn't even cost $50. I'm not sure what the op is trying to get at though, leveling the unit or anchoring for anti-theft.
Thanks.
Old 12-11-2012, 09:44 PM   #22
Make the pad, base or foundation firm, not able to rock back and forth when I give it a little push with three fingers.
Old 12-11-2012, 11:14 PM   #23
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
THIS is exactly why I said spend 500 or spend 20 bucks!
Old 12-12-2012, 05:30 AM   #24
Nah, your not creative enough, can be done without recovering the freon and unhooking everything. THere is enough lip on both sides of the unit where I can put a 4x4 and block it up.
Old 12-12-2012, 10:24 AM   #25
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Good luck with that!
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 09:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 08:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 09:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 08:36 PM
