Ideas For Anchoring Condensor Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 04:16 PM   #1
Ideas for anchoring condensor unit
I'm noticing the condensor unit is tippy and might need some anchoring down. We get occasional heavy winds and I'm not comfortable leaving it as is. I'm afraid it is going to rock back and forth, maybe even fall off a leg if the wind gets blowing hard enough. For sure it can't be good for it.
The pad is an E Lite Equipment pad and made of plastic, and hollow underneath. Not very solid for this application if you ask me.
A couple of ideas i'm kicking around is to support the unit with some wood, pull the pad out and slide a 24 x 24 concrete paver back under it with liquid nails applied to all surfaces. the other idea is to replace it with some pressure treated wood 6 x6 and 4x4.
I'm open to any suggestions how I can anchor this down better?
PS, Yes the lineset is already brazed in place, I realize I have to keep the heat pump unit at the same height.
Thanks in advance...
Ideas for anchoring condensor unit-condensor-pad-001.jpg   Ideas for anchoring condensor unit-condensor-pad-004.jpg   Ideas for anchoring condensor unit-condensor-pad-005.jpg
jfls49 is offline   Reply With Quote
Old 12-08-2012, 04:28 PM   #2
Rewards Points: 13,300
May be tippy because the pad under it is not level and it sure looks like there was not enough fill around it to keep it from washing out.
Old 12-08-2012, 04:34 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Get a roll of this,
And secure it to the wall.
sublime2 is offline   Reply With Quote
Old 12-08-2012, 04:41 PM   #4
Go back and add your location to your profile.
It was installed to close to the house. Should have been out behind the drip ole of the roof.
Old 12-08-2012, 06:06 PM   #5
Those pads are alright for flat surfaces, but I always preferred to poor a concrete pad if there was any slope at all. Most hvac contractors won't go to the trouble, though, as you need to form and poor the concrete a few days before setting the unit down on it, and can't drill into it for 7 days (if my memory serves me). I don't think those pads will stand up to being drilled into for anchors. I think it would take a hell of a wind to blow the unit over, although those columns you have under it change its centre of gravity.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
plummen (12-08-2012)
Old 12-08-2012, 06:46 PM   #6
I doublechecked to see what is under it, stuck my fingers under that corner where there isn't much dirt. Its hollow and feels like plastic.
This pad appears to be some kind of plastic decorative cover that sets over a poured concrete pad.
Old 12-08-2012, 07:09 PM   #7
It was moved out about 18" from the wall. The picture makes it look alot closer.
Old 12-08-2012, 07:15 PM   #8
I'm Your Huckleberry
Rewards Points: 2,270
You can't anchor to a plastic pad, not to mention anchoring is not going to solve the ground shifting. You need concrete or you need to level the ground under the unit, pack it down.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 12-08-2012, 07:22 PM   #9
Can you elaborate? Do I wrap it around the top of the unit securing it at two places to the wall? Would you drill new holes or existing screws that hold the unit together?
Originally Posted by sublime2 View Post
Get a roll of this,
Attachment 61672
Old 12-08-2012, 07:24 PM   #10
Supporting the unit and sliding a concrete paver in there while it is in operation is going to be the hardest part.
Old 12-08-2012, 08:30 PM   #11
Rewards Points: 738
Level the pad and mud jack until all the cavity underneath the plastic is full.
Old 12-08-2012, 08:34 PM   #12
Mud Jacking?
Whats wrong with using one of these?
Old 12-09-2012, 07:31 AM   #13
Rewards Points: 1,216
Jack the unit up remove the pad, go to a Stone/Masonry yard and pick up a precast pad and a couple bags of stone, put stone down and level, position new pad over stone and lower unit down on new pad, no need to anchor unit. Not a easy thing to do dealing with all that bulk weight.
Be careful of them refrigerant lines and wiring.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-09-2012, 08:06 AM   #14
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Your concern is to secure the unit from rocking/ moving in high winds.
Run the strap,maybe 2 straps around top and bottom of the unit and secure to the wall with some tapcon screws.
Ever need to service unit,remove screws and your good to go.
Old 12-09-2012, 09:01 AM   #15
Don't use that strapping it looks like crap, you wouldn't like the look and you will have to drill into your house. Have never seen anything like that in the field. If you really think you have to anchor it down you can go right through the inside of the unit down through the 4 legs into the concrete pad after the pad is changed and the unit is back level and in place. You really shouldn't have to anchor it.
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 10:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 07:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 09:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 10:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 09:36 PM
