Ideal Boiler 1-6 Dial On Front Panel - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 08:40 AM   #1
Ideal boiler 1-6 dial on front panel
Hi,
We have an Ideal boiler that must be about 12 years old. All it has is a 1-6 dial on the front which is set to 2.5. I was wondering what this does? As our central heaters never seem to feel like they get hot enough or stay hot for long, we normally set the living room themostat to 20 degrees C.
Should 2.5 be set higher?
Also we have one of these http://www.tlc-direct.co.uk/Products/TLGD1550.html it sits in our cupboard where our immersion heater is.
On it it says there are 3 settings 40, 60, 95 and our's is set to 60, what does this mean, if I turn it up will our shower be more powerful oris it it just the pump for the central heating?
gonzo is offline   Reply With Quote
Old 06-01-2010, 03:43 PM   #2
An old Tradesmen
Rewards Points: 6,476
Looks like a circ for the domestic hot water recirc loop. The settings just control flow through the recirc loop. Not out of your faucets.
Don't know about your boiler. Try setting it to 3, and see if the heat emitter get hotter.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 12:58 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
