A Idea About Geothermal Heating & Cooling - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2010, 06:49 PM   #16
Is this kind of thing suitable for DIY? It sound really simple. So just replace the air source condenser with coaxial condenser, dig the wells, pump water through the condenser?
BTW, approximately how much will the coaxial condenser cost for a 5 ton heat pump?
Originally Posted by beenthere View Post
You'd need to buy the coaxial condenser for it. Do a lot of trial and error.
deerhunter is offline   Reply With Quote
Old 08-13-2010, 07:28 PM   #17
An old Tradesmen
Rewards Points: 6,140
You could do the change out of the condenser coil to coaxial.
But you would need a HVAC tech to do your recovery and recharge.
Don't know what the cost of a coaxial would be, haven't priced one out for replacement lately.
Old 08-13-2010, 08:51 PM   #18
Doesn't the control circuit need to be modified? For example, the defrost mechanism. There may also be a meter that adjust the pressure according to the outside temperature. When groundwater is used, should it measure the temperature of the groundwater instead?
I also read from somewhere that the air handler need to be matched to the heat pump. Does changing the condenser bring the need to also change the air handler?
Old 08-13-2010, 09:05 PM   #19
An old Tradesmen
Lots of things would need changed.
Better off just buying a self contained geo/water sourced heat pump.
Old 08-13-2010, 10:08 PM   #20
Rewards Points: 156
Here's a simple cookbook!
http://www.geothermalheatpumpforum.o....html#post5610
Knock yourself out.
moondawg is offline   Reply With Quote
Old 08-13-2010, 10:25 PM   #21
Rewards Points: 392
Hey. Put hand holds in it, and then rent time on it.
[/IMG]
That was really HILARIOUS! I was laughing my A off for a few minutes. My wife didn't get the humor however.. I thought it was Very funny.
zootjeff is offline   Reply With Quote
Old 08-13-2010, 10:40 PM   #22
Wow. This is exactly what I'm talking about. I firmly believe that this is something I'd be able to pull off. But I probably won't do it because I may have to change it back or buy and install a new heat pump when it comes to reselling my house. I can't count on the next owner to be able to work with the monster I would have created.
Knock yourself out.
Old 08-14-2010, 03:10 AM   #23
BTW, when people say the air handler need to match the heat pump, they mean to match in what respect?
Old 08-14-2010, 04:51 AM   #24
An old Tradesmen
Tested/rated to work with the condenser/outdoor unit.
A 3 ton Trane condenser is not a match for/to a 3 ton Rheem air handler.
Old 08-15-2010, 12:38 PM   #25
Can the coaxial condenser be matched to the air handler by adjusting the flow rate?
Old 08-15-2010, 02:37 PM   #26
An old Tradesmen
Are you talking the coaxial condenser only, or a water sourced condenser.
All condensing units/pieces, must be matched for the total heat transfer of the indoor unit.
Old 08-15-2010, 09:12 PM   #27
I was referring to coaxial condenser. I mean do you have to do ask an HVAC or geothermal expert to help you buy a coaxial condenser that matches the air handler, or you can buy a coaxial condenser based on the tonnage and operating pressure and work out the optimal flow rate that matches the air handler.
Old 08-15-2010, 09:28 PM   #28
An old Tradesmen
You have to buy it based on your heat sink/heat source.
Upstairs unit not heating or cooling JakAHearts HVAC 5 06-13-2010 10:22 PM
Heating & Cooling Analysis jjrbus HVAC 6 06-12-2010 08:52 AM
Heating Unit in the Attic Bad Idea? Part of House on Slab cloves HVAC 3 08-18-2009 12:37 PM
Changing my heating system, need advice sethfc HVAC 4 08-10-2009 10:46 AM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 08:17 PM
