ICP HQ1085928TX Fan Control Board Burn Up Too Often - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 03:16 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
Arrogance??? who pisssed in your corn flakes?
Of course the copper line may not be grounded but in 99% of homes/cases it is and it a simple DIY friendly method.
How about just adding to the conversation. I know LOTS of electrical but don't jump in to their forums/sites w/o showing some respect.
Old 09-02-2013, 03:50 PM   #17
drop your probes boys!
I also know some electrical but this home has been rewired by someone with NYC codes using BX cable and 12awg wire standard 15amp outlets. I will check that ground and i'll install a new ground rod and wire to the fuse box and to the HVAC unit.
Right now im waiting for the board so when it arrives, i'll recheck the wiring beore installing it and post my findings. Much thanks!!
Malpopies is offline   Reply With Quote
Old 09-02-2013, 04:02 PM   #18
Hvac Pro
yuri's Avatar
Yur Welcome
I suspect it is a grounding issue so improving it is a very good idea. apparently there is some condition in humid areas of the US and probably Canada where the screws in the air handlers corrode/loosen and they get a floating ground. some kinda galvanic reaction. have not seen it where I am but other Pro's I talk to have run into it and it drives them nuts troubleshooting. On some units I run a green ground wire from the ground of the board or transformer secondary/ground directly to the ground wire of the air handler for that reason. Bypasses any chance of loose board mounting or connections.
Let us know if the problem gets solved for others and future reference.
Old 09-03-2013, 07:31 AM   #19
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I apologize for my comment. Something hit me wrong and i shouldn't have snapped on you.
Again, I apologize.
wirenut1110 is offline   Reply With Quote
Old 09-03-2013, 08:19 AM   #20
Hvac Pro
yuri's Avatar
No Problema.
I have very thick skin.
Tags
1085928 , heil , hq1085914tx , hq1085928tx , icp
Bad control board? juddskee HVAC 12 12-24-2011 09:59 AM
Changing Control Board Questions -- HSI module and AC wire connection humdinger0102 HVAC 7 11-17-2011 12:16 AM
Replacing a control board RexHavoc HVAC 5 11-05-2011 03:57 PM
HELP? Control Board Fixed Heat...But Now A/C Won't Turn On - Homeowner KLR HVAC 35 08-15-2009 10:46 AM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
