ICP Furnace Blower Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 03:51 PM   #1
I was told recently that my blower motor is on dying as it is slow to startup and should be replaced. I wanted to go online to see if I could order one and maybe install it myself and if not maybe save a couple $'s at least on the part. My furnace was installed in '96, 75,000 BTU NG. Model # on the furnace is CHGK075AF01
I was also told that the fan only has 2 speeds (medium and high) and I would like to consider an energy efficient motor (if one exists). I have an electronic air cleaner (Electro-Aire) and our Honeywell Vision 8000 thermostat is usually left on CIRC mode so when the fan has not run on the furnace, the thermostat will cycle it automatically. Does the fan for circulation have to run on high though?
SheeB is offline   Reply With Quote
Old 02-07-2010, 06:38 PM   #2
An old Tradesmen
Rewards Points: 7,746
Your control board is set up to run the fan on cooling speed. So what ever speed you need for cooling, is what it will run at.
Old 02-07-2010, 08:11 PM   #3
Ok, so that answers the question of fan speed options then. So does anyone know what I am looking for in regards to the blower motor options?
Old 02-07-2010, 08:43 PM   #4
An old Tradesmen
Same motor as it currently has. Check teh rating on the motor, and get one that matches those. Plus the capacitor for it.
Doesn't matter if the new one is a 3 speed motor.
Old 02-07-2010, 11:04 PM   #5
Ok thanks again for the reply. I was really curious of there was such a thing as a more energy efficient motor that can replace the existing one but I guess I will have to go pull the cover and get the motor specs.
Old 02-07-2010, 11:47 PM   #6
An old Tradesmen
A more energy efficient one. Will cost you a lot more then just replacing with the same type.
If your electric rate is real high. It might pay itself back in 4 or 5 years. If you run your fan 24/7/365
Old 02-08-2010, 03:36 AM   #7
motor is i/3 or1/2 hp. Pop for a half horse four speed motor and you can always decrease the air flow.
hvaclover is offline   Reply With Quote
Old 04-17-2011, 12:32 PM   #8
CHGK075AF01 model furnace
A friend has the same model furnace with a manufacturer # 9684419548 and another # in a framed box 20045402A.
Does anyone know the age of this unit.
There is no sign anywhere on the unit of a serial #.
CISI is offline   Reply With Quote
Old 04-17-2011, 12:42 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 92
serial #s can be hard to decipher. if you can see the gas valve and find a 4 digit code on it like 9812 that may tell you it was built in 1998 12th month. all major parts have a 4 digit date code on them
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace Shuts down B4 Blower motor engages Kooks from Michigan HVAC 5 03-18-2011 12:11 PM
Rheem furnace blower motor does not come on automaticall wrightti HVAC 5 11-12-2008 05:29 PM
Furnace blower motor noise rivershorereid HVAC 1 10-04-2008 02:31 PM
Replace a furnace blower motor dadncharge HVAC 2 12-06-2007 09:42 PM
