ICP Evap. Coil Model EPD24B15C2 - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 09:20 AM   #1
Hi, I have an Acoil manufactured by International comfort Products model number EPD24B15C2 and has a 057 piston/restrictor in it now and its about 5-6 years old. I know others can be changed out to make it bigger or smaller capacity. I;m changing my system to a 2 1/2 ton and wanted to see if this acoil could be switched to a 2 1/2 ton coil? What number of piston would it have to be if so?
evile6996 is offline   Reply With Quote
Old 07-07-2011, 05:52 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
pistons are sized by the requirement of the outdoor unit and the coil can be replaced but may need to do duct work modification to make it work.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-07-2011, 06:27 PM   #3
An old Tradesmen
Rewards Points: 7,270
Your coil can't be used for 2.5 ton
Old 07-07-2011, 06:51 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
the 24 in the model means 24,000 btu = 2 tons. coil can be used for 18,000 or 24,000 btus but not upsized.
Struggling with Home warranty company over evap coil, plenum, etc, please advise! JYale HVAC 7 04-12-2011 04:49 PM
Damaged fins on furnace EVAP coil rlukas79 HVAC 5 12-21-2010 03:10 PM
Evap Coil Replacement Rickhoff HVAC 3 08-24-2009 09:58 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
