Iclimbroofs - HVAC - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 10:57 AM   #1
iclimbroofs
i have a payne 376b furnace. it was wirking fine. then, as it would turn on the pilot would light and thye main burner would try to light. it would go on and immediately shut off, and do this several times and would then light and work properly. then it got to where it would just keep trying, on then off, ect. and would not light.
i replaced the 3 wire pilot switch and no help. i tried a new fan control b oard and same. i am getting 30 volts at brown wire in gas valve, but nothing at other gas valve connections. i could jump brown wire to white wire connection on gas valve with pilot lit and the main burner would light until the jumper was remoned.
i checked the igniter box now , as pilot will not try to light, and i only get 8.9 volts.
i may have goofed something else up with my attempts. i would appreciate any help. thanks
iclimbroofs is offline   Reply With Quote
Old 03-12-2011, 11:09 AM   #2
An old Tradesmen
Rewards Points: 6,544
Check for obstruction in the flue pipe. And for moisture in the hose to the pressure switch.
Old 03-12-2011, 02:51 PM   #3
Rewards Points: 492
Did you clean the flame sensor/thermocouple?
http://www.youtube.com/watch?v=I86jo...eature=related
diyorpay is offline   Reply With Quote
Old 03-12-2011, 02:59 PM   #4
An old Tradesmen
Its a part of the new pilot assembly.
Old 03-12-2011, 05:17 PM   #5
iclimbroofs
thanks beenthere. i blew on hose and no obstructions. measured voltage at spark box, green double wires read 9.2 v, no voltage to blue wires. thanks again. any other suggestions? iclimbroofs
Old 03-12-2011, 08:18 PM   #6
An old Tradesmen
What about the flue pipe?
Old 03-12-2011, 10:08 PM   #7
It is a dirty flame sensor you will not have usual voltage there it works off of microamps
heatycooly is offline   Reply With Quote
Old 03-12-2011, 10:17 PM   #8
An old Tradesmen
His new 3 wire pilot assembly has a new flame sensor.
Old 03-13-2011, 02:24 PM   #9
iclimbroofs
the flue seems ok. i took flue top off roof and could not fine any obstructions. any other ideas? thanks
Old 03-13-2011, 02:42 PM   #10
An old Tradesmen
Remove the flue from the furnace and see if it runs then. If not, could be a bad pressure switch.
Old 03-13-2011, 03:33 PM   #11
Also check the pressure switch tubing I have seen on that furnace the tubing can dry rot
Old 03-15-2011, 11:40 PM   #12
iclimbroofs
sorry i have not responded. i have been called out of town for a while. will try disconnecting flue when i return. thanks for all you help.
