Ice Machine Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2011, 11:32 PM   #1
I've been working on an ITV ice machine for two days. This is the problem: It will make ice, but it will not go into harvest cycle. It has a hot gas bypass valve for harvest purposes. I have confirmed that the solenoid is good but the line is not getting hot at all. The machine goes thru the defrost cycle on the timer but never drops the ice into the bin. I took my torch and heated up the joints and have taken the lines off and there is not any obstruction. I took it off from the compressor up to where it bypasses the TXV and there is no blockage. I have replaced the solenoid and I have replaced the timer. I do have one more Idea though: I was wondering if there is a check valve on the machine and possibly is stuck open. Any comments are welcome on this thread cause I'm Outta Answers. Thanks in advance.
livewire1978 is offline   Reply With Quote
Old 12-27-2011, 02:16 AM   #2
the temperature sensor that sets it into harvest possibly bad?
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
hvactech126 (12-27-2011)
New Dog. Problems. Doc Holliday Off Topic 12 12-26-2011 09:59 AM
Washing Machine not working..? YellowCar Appliances 2 04-27-2011 08:42 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 08:02 PM
washing machine problems theltimatepartyjams Appliances 5 12-21-2008 03:11 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
