Ice Machine Help?? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2013, 08:12 PM   #1
Ice Machine Help??
Anyone have any ideas why a Hoshizaki ice maker would freeze up on the BACK of the evaporator plate only? I have cleaned it throughly and yet the water is still running up over the ribs on the plate and eventually freezing up. I have also tested for any refrigerant leaks and found nothing. The front of the plate makes perfect cubes. Driving me crazy!! Any thoughts or suggestions would truly be appreciated..Thanks, Anson
Anson is offline   Reply With Quote
Old 03-29-2013, 08:16 PM   #2
An old Tradesmen
Rewards Points: 8,242
The water bar, plastic trough is still restricted. Pull it and reclean it.
Old 03-29-2013, 08:22 PM   #3
Thanks for your help, I've pulled it off twice and flushed it, do you think that sediment could still be circulating in the system then? You might be totally on to something here......Thank you...
Old 03-29-2013, 08:25 PM   #4
An old Tradesmen
Seen it before on them. Sometimes the little ports the water comes out clog up almost immediately after you clean it, or the next day.
lush the bar with lots of water in both directions. make sure all ports are clear. And then flush the sump again.
The Following User Says Thank You to beenthere For This Useful Post:
Anson (03-29-2013)
Old 03-29-2013, 08:28 PM   #5
Doing that tomorrow morning then. Great forum here, very glad I joined. Thanks again, Anson.
Old 03-30-2013, 06:45 AM   #6
Rewards Points: 1,216
When you say that you cleaned it do you mean cleaned according to the owners manual? And did you use approved ice machine cleaner (only purchased in a HVAC supply house) ? Which is acid. Then after cleaning throw away the first few harvests. Post back let us know what's happening. Ice Makers can be challenging even for experienced Pros"s
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-30-2013, 12:21 PM   #7
Thank you for taking the time to try and help me with this.... I cleaned it with nickel safe ice machine cleaner again this morning and its still messing up! Question: is it normal to have an air bubble in the top of the plastic tube with the jets? The jets are all streaming nicely and consistent. Another question: some cubes seem to be getting deformed and causing the water to run up and along the sides of SOME ribs on the evaporator plate, could this be the cause? The defrost cycle seems to work fine though. If it's too much then I will call someone but I really don't like getting beat by a machine! Thanks again for your time, Anson.
Old 03-30-2013, 12:23 PM   #8
Sorry, yes, cleaned it according to owners manual.
Old 03-30-2013, 12:25 PM   #9
An old Tradesmen
Its normal to have an air pocket. Did you pull the tube and clean each jet/port out.
Old 03-30-2013, 06:58 PM   #10
Yes, I pulled the tube out and blasted it again with water. I also cleaned all the jets individually and they are all streaming nicely. It seems as tho that when 1 ice cube starts becoming deformed the water goes up and over the sides of the ribs causing "saddling". Is there something I could use to "scrub/polish" the evaporator plate or would that do more harm than good? It really seems like something on the plate is causing a few deformed cubes and snowballing from there. If you guys are tired of this subject I totally understand.....thanks tho..
Old 03-30-2013, 08:07 PM   #11
An old Tradesmen
Brass brush.
Old 03-30-2013, 08:42 PM   #12
Brass brush.
That's great!! Thank you...
Old 03-31-2013, 09:56 AM   #13
I have to bail out . Without being there and watching the cycles and flows and temperatures it's to difficult to walk through it on the forum.
Good luck and listen to beenthere hopefully he will be able to walk you though it. Coldiron out.
Old 03-31-2013, 11:28 AM   #14
I totally understand, like trying to explain computer stuff over the phone to my mother in-law!! I think the evaporator brush is the answer. Going to find a nylon brush today (not paying $110) for one from hoshizaki! Thanks everyone for the help, it really is appreciated.
Old 03-31-2013, 11:43 AM   #15
Rewards Points: 242
Has the water pump been replaced with a after market one. Maybe to much pump pressure. Some machines used to have a clamp on the water line going to the plates to restrict how much water is going over them. I cant remember what brands.
hvac instructor is offline   Reply With Quote
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 12:07 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 07:14 PM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
