Ice In Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 10:49 PM   #1
ice in furnace
hey, i have ice build up in furnace blocking cold air from entering my house, please help
jjlis is offline   Reply With Quote
Old 06-22-2009, 10:51 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
You have one of two things wrong
1. Filter is plugged
2. A/C is lon on freon
When was the last time you replaced your filter?
Old 06-22-2009, 11:05 PM   #3
Home Air Direct's Avatar
To expand on the plumber, after you change your filter, turn off the power to your outdoor unit and allow the furnace to run with the blower on. If the ice has not completely frozen up the coil, it will melt (in hours). Once you have defrosted your coils, turn the system back on and set to your desired temp.
If the system ices up again, you are low in refrigerant and you need to call for service, either to charge and or find the leak in the system if there is one.
Good luck.
btw.....I fielded this same question earlier today. After I gave the above answer, the homeowner responded back to me "What Filter?"
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-22-2009, 11:11 PM   #4
Rewards Points: 560
Good point Home Air
If I'm in a hurry I'll turn on the furnace for about 5 mins to help speed up the process
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
