I Turn My AC Unit Off But The Compressor Fan Still Runs - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 08:43 AM   #1
I turn my AC unit off but the compressor fan still runs
My air has been running just fine but yesterday when I shut it off (it was finally below 90) the compressor fan (I think, it's the one on the outside unit) kept running. Is this a problem with the relay switch? If so, where can I locate it? I'm fairly handy so I don't mind doing my own fixes but I know very little about AC so if anyone can direct me as to where to look and how to fix it, I'd greatly appreciate it.
mongoose5271 is offline   Reply With Quote
Old 07-26-2011, 09:02 AM   #2
I meant to say my condenser fan.....
Old 07-26-2011, 09:35 AM   #3
JJboy's Avatar
Check the contract, may be stuck. Turn off your AC on thermostat. You should have a safe switch close by the condenser.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-26-2011, 09:42 AM   #4
I did turn the unit off from the thermostat and the waited for about 15 minutes and the condenser fan was still going so I went outside and removed the fuse plug (is that the right term?) because I didn't want the motor to burn out. I then waited about an hour and put the fuse plug back in. The fan started going immediately so I removed the plug again and that is currently where I am at with this.
Old 07-26-2011, 09:46 AM   #5
JJboy's Avatar
Your contactor is stuck.
The Following User Says Thank You to JJboy For This Useful Post:
mongoose5271 (07-26-2011)
Old 07-26-2011, 09:51 AM   #6
Mad Scientist
Is the compressor still running too, or only the fan?
Be extremely careful around the outside unit, as one potential cause of that symptom is a ground fault in the outside unit's wiring. Such a fault can cause all the metal parts of the outside unit to be electrified.
McSteve is offline   Reply With Quote
Old 07-26-2011, 10:20 AM   #7
Regarding that diagram: Is that what I'll find if I remove the panel on the outside unit?
Old 07-26-2011, 10:23 AM   #8
Mad Scientist
Yep. Just in case of a ground fault, shut off the power to the outside unit before you attempt to remove the panel.
Can you tell if the compressor and fan are both running, or just the fan?
Old 07-26-2011, 10:24 AM   #9
Absolutely. Just the fan is running as far as I can tell.
Old 07-26-2011, 10:27 AM   #10
Mad Scientist
If the compressor still starts and stops normally when you turn the thermostat on and off, it's not the contactor. Do you have a multimeter?
Old 07-26-2011, 10:31 AM   #11
Well the air runs fine if I turn it back on via the thermostat; is that what you mean? No I don't have a multimeter.
Old 07-26-2011, 02:34 PM   #12
Mad Scientist
might be time to just call a tech, I'm afraid. Without a multimeter there isn't much more troubleshooting you can do.
The Following User Says Thank You to McSteve For This Useful Post:
Old 07-26-2011, 02:41 PM   #13
biggles's Avatar
shut the stat no cool call..then shut the disconnect next to the condenser...remove the access panel on the outside section/condenser and the electrical panel..."alls off with no call or power" can you push the contactor in/springs back out with a pencil or pen...or is it stuck closed..when that closes when your stat calls the compressor and fan both start....
Old 07-26-2011, 02:52 PM   #14
OK. Appreciate the help.
Old 05-12-2015, 06:02 PM   #15
I can see this is way late. But just off the odd chance that someone else is finding this looking for a solution. Had a call yesterday with these indicators. After the call for cooling had stopped the condenser fan would continue to hum Not fully on. What had happened was one leg of the motor had a short to ground. Another leg of the motor was connected to a "shank" contractor. This means that leg always has 120v and would complete its circuit to ground and try to run the fan with 120v.
Moral of the story is with these symptoms you will most likely need a tech to come and replace the fan motor.
Kurt698939 is offline   Reply With Quote
What Temps Should York AC Unit Be? - Is it Me or Does my AC kind of work? mrpman HVAC 7 07-24-2011 06:59 PM
Deck Landing and A/C Unit Master Brian HVAC 10 07-22-2010 07:08 PM
Condenser unit quits working on regular basis.. big-e HVAC 16 07-22-2010 05:44 PM
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 03:59 PM
Cant figure out why the fan on my AC unit runs continueously markb1313 HVAC 1 07-05-2010 04:14 PM
