I Should Be Able To Figure This Out... Dryer Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2008, 06:11 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I should be able to figure this out... dryer vent
OK, so I have a stackmate W/D. They are going up against a 2x4 interior wall, so I need to vent through the floor of the 2x4 wall and go out from there.
I see some dryer boxes with oval outlets on them ( http://www.dryerbox.com/ ). Do they make oval pipe or is it OK to squish the round pipe into an oval shape? Plumbing pipes are not allowed to be strained at all, so i'm like .
I was going to use one of those deals with the round inlet/outlet on the end adapted 90 degrees to a square vent, ( http://repair2000.com/18_inch_vent.jpg ) but it isn't long enough. Now I need to do something else. I only need to put a single 90 on it to go from vertical to horizontal, is there a special kind of fitting, or just a 4" aluminum 90 will work?
I'm a plumber, this should be easy... fittings.... pipe... double ya tee eff?
Journeyman Plumber
Old 10-16-2008, 06:28 PM   #2
the Musigician
DangerMouse's Avatar
i don't think that's an oval hole, it's round....it's camera angle is all. http://www.dryerbox.com/
DM
Old 10-16-2008, 06:52 PM   #3
Doing it myself
Alan's Avatar
DM
Journeyman Plumber
Old 10-16-2008, 08:05 PM   #4
the Musigician
sorry, my bad.... weird, huh?
DM
Old 10-16-2008, 08:33 PM   #5
DM
No. It's oval. Check the size specs for the 350.
jerryh3 is offline   Reply With Quote
Old 10-16-2008, 09:20 PM   #6
30 year tech
hvac122's Avatar
If your trying to put 4" pipe in a 2x4 wall the box will be ovaled as shown. The drywall will bow around the pipe also if box is up where the vent on the dryer comes out. We do this all the time. Just oval the pipe and hook up the dryer vent to that. It would be hard to put a elbow on the ovaled pipe without breaking a gore but it can also be done.
hvac122 is offline   Reply With Quote
Old 10-16-2008, 09:38 PM   #7
Doing it myself
Alan's Avatar
when i went to the hardware store, the only elbows they had were adjustable ones that swivel to make up odd angles. Is that the right fitting?
Journeyman Plumber
Old 10-17-2008, 08:18 AM   #8
30 year tech
hvac122's Avatar
Yes they should be. The part where it adjusts is the gore I was talking about. These can break when trying to oval out. Be carfull and it should work.
Old 10-17-2008, 09:03 AM   #9
RippySkippy's Avatar
When you fasten the pieces together, don't use screws (lint magnet) use Aluminum HVAC tape around the entire joint...it will not come apart.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-17-2008, 09:19 AM   #10
Why not just get an oval to round adapter? A heating supply place should carry that. Most hardward stores and big boxes like HD and Lowes don't carry oval parts.
dac122 is offline   Reply With Quote
Old 10-17-2008, 10:04 AM   #11
30 year tech
hvac122's Avatar
I don't think I have ever seen a 4" oval to round adapter. I suppose they do make them as they do almost everything else. I don't think one would fit in the dryer box and still have enough room to install a elbow.
Old 10-18-2008, 07:10 AM   #12
don't know how far the run is but the vent on these is critical. remember if the washer needs service the dryer has to come off.
Jacques is offline   Reply With Quote
Old 10-21-2008, 08:23 AM   #13
They have a tips video for handling the oval hole:
http://www.dryerbox.com/flex_hose_tips.htm
SemiHandy is offline   Reply With Quote
Old 10-21-2008, 08:59 PM   #14
Just use the Aluminum 90 you bought thats what I always do. I run lots of dryer vents just like you've described.
Rookietinner is offline   Reply With Quote
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 11:25 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
Dryer vent and AC compressor - min. distance? RDS HVAC 5 05-04-2008 07:50 AM
Dryer Vent Question jlaky2000 HVAC 2 03-13-2008 09:22 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
