I Need More Heat In A Living Room. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2012, 03:59 PM   #1
I have a living room that was an addition. There is only one 6" duct running into the front of the room. The room is 12x20. The duct os on the 12' side under the step down into the room. At the other end is a wood stove that i plan to replace to a gas stove someday. The room is not receiving enough heat. Would a booster fan help? What else could i do? I forgot to mention the room is on a slab.
Mallard1123 is offline   Reply With Quote
Old 10-20-2012, 05:14 PM   #2
how
Rewards Points: 1,104
So is the heat coming out of the outlet where the step down is at the entrance to the living room.. and then just immediately leaving the livingroom for the closest return air in your home?
Is the gas stove going to be thermostat controlled?
how is online now   Reply With Quote
Old 10-20-2012, 08:20 PM   #3
An old Tradesmen
Rewards Points: 7,344
Find a way to run another 6" supply to that room.
Old 10-20-2012, 08:52 PM   #4
It comes right out under the step, there is no return in the room. The only way i could run another pipe is next to the one that is already there. I need air to the other end of the room.
Old 10-20-2012, 09:55 PM   #5
An old Tradesmen
Ain't goona get air to the other end from one 6" supply.
Old 10-21-2012, 06:43 AM   #6
Rewards Points: 582
is it possible to remove the 6" and replace it with 8" you would get more cfm which may help....ben sr
Old 10-21-2012, 07:31 AM   #7
I dont think there is enough room. Theres wires running through the joist.
The Following User Says Thank You to Mallard1123 For This Useful Post:
ben's plumbing (10-21-2012)
Living room floor Barry J Flooring 1 04-13-2012 01:50 PM
Replacing carpet in living and dining room. Need advice! mandingo Flooring 2 02-24-2012 11:41 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 09:19 AM
Suggestions for Living Room gante Interior Decorating 3 03-06-2009 11:56 AM
