-   -   I need more heat in a living room. (http://www.diychatroom.com/f17/i-need-more-heat-living-room-160643/)
Mallard1123 10-20-2012 04:59 PM
I have a living room that was an addition. There is only one 6" duct running into the front of the room. The room is 12x20. The duct os on the 12' side under the step down into the room. At the other end is a wood stove that i plan to replace to a gas stove someday. The room is not receiving enough heat. Would a booster fan help? What else could i do? I forgot to mention the room is on a slab.
how 10-20-2012 06:14 PM
So is the heat coming out of the outlet where the step down is at the entrance to the living room.. and then just immediately leaving the livingroom for the closest return air in your home?
Is the gas stove going to be thermostat controlled?
beenthere 10-20-2012 09:20 PM
Find a way to run another 6" supply to that room.
Mallard1123 10-20-2012 09:52 PM
It comes right out under the step, there is no return in the room. The only way i could run another pipe is next to the one that is already there. I need air to the other end of the room.
beenthere 10-20-2012 10:55 PM
Ain't goona get air to the other end from one 6" supply.
ben's plumbing 10-21-2012 07:43 AM
is it possible to remove the 6" and replace it with 8" you would get more cfm which may help....ben sr
Mallard1123 10-21-2012 08:31 AM
I dont think there is enough room. Theres wires running through the joist.
