I Need Measurements For Plenums - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 10:40 AM   #1
I need measurements for plenums
I have a furnace comfortmaker rpj ii model gui075a012ain and need to order a plenum and a return part, but i do not know thwe exact measurements for this model. Can you please help?
TANNY is offline   Reply With Quote
Old 01-05-2012, 10:47 AM   #2
Rewards Points: 13,994
Not really a DIy project.
Old 01-17-2012, 08:26 PM   #3
011010100110111101100101
Rewards Points: 160
Why is that?
-- Joe
anesthes is offline   Reply With Quote
Old 01-17-2012, 08:41 PM   #4
Rewards Points: 582
well joe is really right ...duct work should be sized correctly for the furnace to function as intended if not .. could ruin furnace and hurt someone?????
Old 01-17-2012, 09:02 PM   #5
19 1/4" side 14 " front. This is the supply air plenum.
But why not just measure for your self?
hvac5646 is offline   Reply With Quote
Old 01-17-2012, 09:04 PM   #6
Rewards Points: 160
This document is over 30 years old, but it gave me an education
http://www.toolbase.org/PDF/DesignGu...ct_systems.pdf
Along with the manuals that came with my furnace.
Now I'm just trying to figure out if I want the furnace to be in the middle of the basement with plenums running in both directions, or at the end of the house with one long plenum. I think it will work better with two plenums.
-- Joe
Old 01-17-2012, 10:12 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is therte an existing furnace in the house?
Are you needing a transition to tie into existing duct work?
plummen is offline   Reply With Quote
Help with measurements HildaFayat Interior Decorating 3 05-22-2011 05:02 PM
Need help getting measurements of pieces I need to cut to build coffee table. JaronDaWizard Building & Construction 2 05-01-2011 09:27 PM
thinset thickness for finished measurements? lifeisadimensio Flooring 3 03-02-2011 10:59 AM
Window Measurements UpComingBuilder Remodeling 5 03-21-2010 12:49 PM
Gambrel Roof Measurements Hoff77 Building & Construction 2 03-15-2009 03:54 PM
