Old 11-05-2009, 11:35 PM   #1
Default I need help replacing a thermostat
I have a Carrier single stage heat pump that goes to a carrier propane furnace when the temperature drops below a certain temperature. As I understand it, which is not very well, there is a temperature gauge in the heat pump that will shut the heat pump off when the temperature drops below 32 degrees or so. The equipment is 15 years old. It came with a Carrier thermostat that is not programmable. The wall plate on the thermostat says Q674L 1454 HH93AZ197. The control part says T874R1384 HH07AQ170. It is wired as follows:
O - Orange wire
W2 - No Wire
C - Blue wire
L - No wire
Y - Yellow wire
R - Red wire
G - Green wire
E - Black wire
I purchased a Honeywell TH8320U1008 that I would like to replace it with. I just want to make sure I don't screw it up when I change it out. I assume I should follow the same color coding but I wasn't sure what to do with the Black wire (Aux. or Emergency). Could someone help me with the correct wiring of the new thermostat and the set-up codes. Some of the the set up questions I'm not sure about. Thanks for any help you can provide.
feltdog is offline   Reply With Quote
Old 11-06-2009, 12:01 AM   #2
Houston204's Avatar
O/B = orange
Aux & E = black (use a jumper wire)
C = blue
Y = yellow
Rc & R = red
G = green
option 170 = 7
190 = 0
Houston204 is offline   Reply With Quote
Old 11-06-2009, 10:40 AM   #3
Houston - Thanks for the information. Can you tell me if the following would also be correct?
200 - 1
210 - 1
240 - ?
250 - ?
260 - ?
270 - 5
340 - 2 Is this the temperature gauge that is in the heat pump?
350 - ?
360 - ?
Old 11-06-2009, 08:29 PM   #4
Houston204's Avatar
200 = 1
210 = ? Do you have a fossil fuel kit? If you do not, you will need the listed C7089U1006 Honeywell outdoor temperature sensor. If you do have an external fossil fuel kit, 210 = 1
240 = this option shouldn't appear since you have already set 170 to 7 (multistage heat pump)
250 = 5 for an 80% furnace (metal vent pipe) or, if you have a 90% furnace with PVC venting, 240 = 3
260 = you do not have a third stage, with 170 to 7 this shouldn't appear
270 = 5 for an 80% furnace (metal vent pipe) or, if you have a 90% furnace with PVC venting, 240 = 3
340 = 0 unless you have the optional Honeywell C7089U1006 sensor
350 = 0 unless you have the optional Honeywell C7089U1006 sensor.
Again, this option will not appear because we will have option 340 at 0.
360 = Again, this option will not appear because we will have option 340 at 0. The fossil fuel kit that you must already have will control this.
If you do have the Honeywell outdoor sensor (not Carrier's) post back for different settings.
More On This Topic
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Saving money on the energy bill is something every homeowner wishes to do. But what's the best way to go about doing it? One of the first things you should do when you want to create a more energy efficient home is upgrade your existing appliances. Buy a... Read More »
Economizing means reducing waste and expense. But it doesn't mean you have to sacrifice the basic pleasures in life. If you cut corners, you can reduce your cash outflow without greatly changing your lifestyle. Read More »
Replacing thermostat...................... sktn77a HVAC 6 09-03-2009 12:07 AM
Questions about replacing a thermostat janralix Electrical 3 08-07-2009 07:29 AM
replacing an old heat thermostat dstm44 HVAC 1 11-01-2008 06:55 PM
Replacing Freezer Thermostat With Wal-Mart Digital Home Control? downplay HVAC 0 05-31-2008 04:30 PM
Thermostat compatibility sfbike2003 HVAC 0 11-23-2007 11:15 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
