I Need Help With Leaking Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 08-01-2009, 10:28 AM   #1
mdm
I need help with leaking air handler
Hi everyone,. I'm new here and this looks like a site with a lot of good info. I have a air handler that is leaking from the main pan into the secondary pan. If the hole or leak is not too bad is it repairable like filling it with some type of caulk or fiberglass resin. I got a repair estimate of 1,800 dollars to change out the air handler. I gues that includes a new coil. It would be nice to be able to patch the leak and get a little more mileage out of this. Any help would be welcome. Thanks.
mdm is offline   Reply With Quote
Old 08-01-2009, 06:41 PM   #2
biggles's Avatar
with the side panels off the air handler you should view the lenght of the main condensate pan within the unit...dry it out and leave it off till after the repair.take a tube of clear silicone and hit all the corners of the pan and the base...then with a cheap paint 1" paint brush coat the remaining sides with a couple of passes...let it dry.if you see the hole in the pan focus on that first then do the rest of the pan.
Old 08-01-2009, 09:10 PM   #3
mdm
Thanks.
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 05:52 AM
Space Pac Air Handler Wiring--208-230/60/1 Volts metal121 Electrical 4 05-05-2009 10:20 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
Air Handler leaking when cycle ends mannaserv HVAC 1 09-04-2007 09:02 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
