I Need Heat, Please Help. - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 01:38 AM   #1
I need heat, please help.
its 230 in the am I'm freezing n luxpro thermostat is not working idk what to do I'm new.to.this house I thought it was working my ac works fine.but.I need heat
sillygirl is offline   Reply With Quote
Old 12-04-2010, 09:26 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
how do you mean the stat is not working, no display? Replace the batteries, otherwise its most likely not the stat and something in the furnace
hvactech126 is offline   Reply With Quote
Old 12-04-2010, 10:55 AM   #3
the ac works display fine
Old 12-04-2010, 10:58 AM   #4
AKA HVACTECHFW
time to call a pro unless you want to troubleshoot the furnace
Old 12-04-2010, 11:01 AM   #5
An old Tradesmen
Rewards Points: 7,830
Did you remmber to switch the thermostat to heat.
Did you try turning the power off tot eh furnace for a minute, and then back on.
Is it a furnace or heat pump. or boiler.
Old 12-04-2010, 04:26 PM   #6
I took it off many times the switch stays on heat I really don't know I have a that thing that heats water and it works because I have hot water....lol I can't.remember what its call its round and white
Old 12-04-2010, 05:08 PM   #7
An old Tradesmen
Water heater.
Old 12-06-2010, 01:27 PM   #8
well I have a central air unit...that's all I know...someone told me I might need to replace the coil...either way I need to get a professional out here
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
