I Moved Themostat 20 Feet And My A/C Doesn't Work Anymore - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 12:49 AM   #1
Rewards Points: 89
I moved themostat 20 feet and my A/C doesn't work anymore
Hi,
I need help. I had to move a thermostat 20 feet (so I extended the wire another 20 feet) and now the central heater and A/C stopped working. The only thing that works is the fan.
There are 4 black wires coming out of the wall to the thermostat. If you look at the back of the thermostat, the wires are labeled....
RH (which is also jumped to RC)
G
W
Y
I read from another website that the W and Y wires are to control the Heating and A/C. Do you think it is possible I reversed these wires? If I try to swap them to test it out, will it damage the system?
Right now....
- If you turn on the A/C, it only works as a fan. (No cold air.)
- If you turn on the heater, it doesn't do anything.
- If you turn on the fan only, it works perfect as a fan.
stanlam is offline   Reply With Quote
Old 10-17-2011, 01:28 AM   #2
JJboy's Avatar
Did you install an extension cable where it was the thermostat to the new position or installed a new cable from thermostat ( new position ) to the controller board?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-17-2011, 01:40 AM   #3
Rewards Points: 89
It was an extension cable.
Old 10-17-2011, 01:45 AM   #4
JJboy's Avatar
Turn off the furnace .... just follow the colors to make the connections
Old 10-17-2011, 01:48 AM   #5
Rewards Points: 89
I'm confused. I can't even turn on the furnace. Also, all 4 wires that are coming from the wall are black, so there are no colors.
Old 10-17-2011, 01:59 AM   #6
JJboy's Avatar
If you marked the wires that were connected to the thermostat...it will be easy for you...... now if you disconnected the black wires without any identification, you will need a multimeter to identify each wire .....this is the best way to save your controller board, fuse or transformer.
Old 10-17-2011, 02:06 AM   #7
Rewards Points: 89
Hi,
I did mark the wires. However, I'm wondering if I marked it incorrectly.
Old 10-17-2011, 02:13 AM   #8
REP
Instead of cobbing the job,why don't you go and buy enough 18-4 real thermostst wire (18-5 would be even bgetter in case you ever needed an extra wire for a set back stat ) and connect the new wire like it should be.
I don't like spliced wire anyways,it too easy to not get a good connection.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
stanlam (10-18-2011)
Old 10-17-2011, 02:26 AM   #9
Rewards Points: 89
I will probably have to do what you are suggesting as the last resort. For now, does anybody know if I can swap the W and Y wire to see if it will work. Running a completely new thermostat wire will take about 5 hours to hide the wire and run it from the 2nd roof to the center of the house on the 1st floor. Swapping the W and Y wire will take about 5 minutes.
Old 10-17-2011, 02:33 AM   #10
JJboy's Avatar
You have R-G working ( FAN ON ). disconnect these wires at thermostat.
try these combinations:
R-W - call for heat
R-Y-G - call for cooling
Don't do R-W-G......
The Following User Says Thank You to JJboy For This Useful Post:
Old 10-17-2011, 06:25 AM   #11
Rewards Points: 1,216
Try what JJ said and if your still having a problem listen to REP and take 5 hours and run new thermostat wire from the air handler/heater to the thermostat. Look how much time your wasting messing with all the same color wires that are suspicious from the start. Who ever first installed that system was &^^%#^%. 18-5 and keep the spare.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 10-17-2011, 09:49 AM   #12
I'm Your Huckleberry
Rewards Points: 2,270
If you were to tie onto the new extended stat wire at the new location with the new 18-4 colored wire and just pull it back to where the old stat location was, where the splice is, it should take you all of 15 minutes.
From there you can splice color to color. Use small blue or gray wire nuts.
Running all new stat wire from the furnace to the new location shouldn't take any longer than 45 minutes.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 10-18-2011, 12:20 AM   #13
Rewards Points: 89
I will try this weekend and post the results. Thanks.
Old 12-18-2011, 12:16 AM   #14
Rewards Points: 89
sorry, I know this post is 2 months to old. However, I did want to respond for future reference. The problem was the wire, it was to long and the wrong type. So the problem was solved after installing the correct wire. Thanks for your help.
Old 12-18-2011, 06:35 AM   #15
Good job, you sure that was the only thing wrong?? Not wired correctly?
asbestos Donnie L. Safety 57 11-27-2012 02:57 PM
New work vs Old work Tetranitrate Electrical 3 07-12-2011 08:19 AM
Newbie needs to build a deck addition toolbot Building & Construction 16 05-10-2011 11:58 AM
Lets Play The "How Much Stain Will I Need?" Game! Bgm94 Painting 5 02-11-2011 09:53 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
