I Live In A Very Small House And My Utilities Bills Are Outrageous. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 12:17 PM   #1
I live in a very small house and my utilities bills are outrageous.
Electric close over $200.00 and gas over $100.00. The house less than 900 sq. ft. It's also a duplex so one wall in "insulated" by the unit next to us. The electric during the summer is double same with gas during the winter. I know the house needs insulation but IMHO the venting is an ever bigger problem but much less costly to correct. I have a atomic clock that sits about 3 feet away from a window and the thermostat is located about 18 feet from that on a wall in the center of the house and 12 feet away from the HVAC unit. The thermostat will be showing 73 degrees the clock by the window will be at 64degrees. The HVAC is located in the middle on the house and the main trunk for the vent is directly overhead and runs down the middle line on the house. The vents on one end are located directly in the trunk on the end and on both sides. The vents for the bedrooms are on the other end and are flexible pipe only about 3-4 feet long. None of the vents are close to being on the outer wall over the windows.
My question is will correct my heating and A/C problems and the outrageous bills?
near3 is offline   Reply With Quote
Old 02-01-2011, 12:28 PM   #2
Experienced
Jackofall1's Avatar
Moving vents to the outside walls will not solve the heat loss/heat gain you are experiencing, it may make if feel more comfortable, but sounds like you need some insulation to be installed there.
Old 02-01-2011, 12:36 PM   #3
I guess that's it. It's never comfortable in here.
Old 02-01-2011, 12:50 PM   #4
The first step is to seal up all the gaps and cracks. It won't matter how much insulation you have if the wind just blows through. Put the back of your hand near electrical outlets. If you feel a breeze, then you need to fix that. Same thing with gaps around your windows and doors, and the openings in the ceiling for light fixtures.
You might look into seeing if there's a way to insulate your duct work, too. If it's running in the attic, then you will loose a lot of heat (or AC) into the attic space. In the summer, the heat in the attic will radiate into the duct, which will warm the air up before it ever gets inside your house.
pyper is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Do you live in an ICF house? davehultin Building & Construction 37 12-06-2010 10:33 PM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Demo small house... MLO Building & Construction 9 02-22-2007 08:43 PM
