I Installed A New Thermostat And The Fan Will Not Stop Running. The Wires Are Correct - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 12:23 PM   #1
I installed a new thermostat and the fan will not stop running. The wires are correct
I tried 3 different thermostats and the fan will not stop running. The house is heated by gas and the pilot light is on. The thermostat is also set to auto with the set temp being 41 degrees and the house temp is 62.
TSA0282 is offline   Reply With Quote
Old 03-02-2009, 02:47 PM   #2
30 year tech
hvac122's Avatar
Are you changing the thermostat because the fan will not stop or was that a by product of changing the thermostat?
hvac122 is offline   Reply With Quote
Old 03-02-2009, 03:20 PM   #3
An old Tradesmen
Rewards Points: 7,816
Usually, if some different happens right after you install a new thermostat.
You either have the wrong kind of stat, have it set up wrong, or wired it wrong.
As above, why did you change the stat.
What brand and model stat is it, and what brand model furnace.
