I Hear A Drip Upstairs Before Heater Turns On - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 12:42 PM   #1
I hear a drip upstairs before heater turns on
The drip sound seems to only come around 1-2 minutes before the heat turns on, it seems to drip one audible drop every seconds until the heat trns off. I have digital auto thermostats and one unit for upstairs and one for downstairs. I also have noticed a very faint discoloration on the ceiling in the living room, suspiciously in the "area" where I can hear a drip. Any ideas?
diyraleigh is offline   Reply With Quote
Old 02-17-2009, 01:36 PM   #2
What brand of furnace and what efficiency is it?
hvaclover is offline   Reply With Quote
Old 02-17-2009, 02:44 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,042
Ayuh,...
It sounds like it's Leaking,.. causing Damage,...
Probably should investigate further,+ nail it down to the Exact Location of the Leak,....
Or,..
Call in a Professional to do it for you...
Bondo is online now   Reply With Quote
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
