Old 11-07-2012, 02:12 PM   #1
I have not heat and we are freezing LENNOX G12 FURNACE NO HEAT.
Lennox G12 series fan starts first and the pilot goes in 2 seconds, not heat. Please help.
jovacano is offline   Reply With Quote
Old 11-07-2012, 02:15 PM   #2
I already replaced the flame sensor thinking that was the issue...same problem fans starts first and the sparking goes crazy pilot lights on for just 2 o3 seconds...anybody out there who knows about lennox HELLLLPPPP PLEASE.!!
Old 11-07-2012, 02:17 PM   #3
I'm Your Huckleberry
Place the sensor in a better position in the flame. Make sure all wire connections are tight, including ground wire. Does the control board have a ground? Is the high voltage have a ground that's connected?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-07-2012, 05:49 PM   #4
Make a call to a good service company. That furnace is around 30 years old and you want a safety check every year to make sure the heat exchanger isn't cracked. They can tell you what's wrong while they're there inspecting the thing.
Carrier furnace short cycling between Low and High heat drtbk4ever HVAC 16 01-15-2012 09:38 AM
furnace not putting out heat nilmerf HVAC 3 12-03-2011 08:59 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 09:24 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
