I Have A Carrier 58GFA Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 07:34 PM   #1
I have a Carrier 58GFA Furnace
Hi
I just bought a condo with a 58GFA gas furnace. When I light the pilot, turn the valve to on, then turn on the furnace, the induction motor runs ok, the main burner lights and looks ok for about 5 seconds, then it look like the pilot goes out and the thermocouple turns the valve off and it all goes out.
I've replaced the pilot burner anf thermocouple, but same problem.
Anyone have any ideas?
thanks
mfdavison is offline   Reply With Quote
Old 02-25-2012, 07:58 PM   #2
how
Rewards Points: 1,102
You will get cleaner responses if you start your own thread.
But...
some folks with that particular furnace have found that a draft from the external fan attached to the Inducer motor blows that very sensitive pilot around enough to get it to drop out. A sheet metal wind sheild between the inducer fan and the pilot assy has been an inexpensive solution for some.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (02-25-2012)
Old 02-26-2012, 05:06 AM   #3
An old Tradesmen
Rewards Points: 6,574
Made this its own thread.
Old 02-26-2012, 08:22 AM   #4
could also be either pilot press needs adjustment or gas control is bad also.
hvac5646 is offline   Reply With Quote
Carrier furnace problem. Pilot lights, no burner Donut HVAC 1 02-09-2011 09:07 PM
What are the carrier furnace codes? porang HVAC 1 01-24-2011 08:45 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 06:16 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 10:48 AM
