I Have An American Standard Allegiance - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 10:18 PM   #1
I have an American Standard Allegiance
I have an American Standard Allegiance 10 built in June 2000.
Model # 7A0036A100A2
The past few weeks, it had been blowing the 60amp Circuit Breaker with temps in the 90's and low 100's.
Last night, around 1AM, the 60amp AND the 100AMP MAIN CIRCUIT BREAKER blew!!!
This morning, I found that with the thermostat at OFF, the fan on the condenser unit was still turning. The relay is humming. It clicks, but does NOT chatter, when I have the cutoff pulled and turn the thermostat to "COOL".
But, as soon as the "CUTOFF" is replaced and I turn thermostat to "COOL", the compressor clicks loudly and both the 60amp and the MAIN BREAKER trip off.
Any ideas?
TONY O is offline   Reply With Quote
Old 07-23-2012, 04:21 AM   #2
An old Tradesmen
Rewards Points: 7,816
Good chance the compressor or its crank case heater has a short in it. Do you have an ohm meter.
Old 07-23-2012, 04:22 AM   #3
HVAC Contractor
Rewards Points: 316
Grounded compressor, most likely, along with bad fan motor and other various components. Time to call your HVAC professionals.
And if you're running the house on a 100 amp panel, you might want to have someone look into that, especially if you're using 60 amps for the A/C. Might be time to upsize the service in the house.
scottmcd9999 is offline   Reply With Quote
Old 07-23-2012, 07:15 PM   #4
I have seen in some isolated cases where system had a one pole contactor and one winding shorted to ground where the fan motor would run by a back feed of voltage. Don't know if this applies here as the 2 time I had this happen was with york units. This unit should have a two pole contactor.
turnermech is offline   Reply With Quote
Old 07-23-2012, 08:00 PM   #5
Rewards Points: 582
Any ideas?
tripping main breakers ..good sign dead compressor...squeese alittle freon from the big line suction side ..smell it to see if it smells burnt..and see if it black....
American Standard Toilets rick31797 Plumbing 1 06-05-2012 07:16 AM
American Standard Mr Smiley HVAC 4 02-24-2012 02:38 PM
American Standard Allegiance A/C pbrjtr1 HVAC 6 04-12-2011 12:14 AM
american standard allegiance 10 AC motor question racebum HVAC 2 08-17-2010 01:47 AM
Godman, Lennox, or American Standard homeowner12 HVAC 2 10-13-2009 05:54 AM
