I Have 2 Technical Question - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 07:21 PM   #1
JJboy's Avatar
I have 2 technical question
1- Delta temp - How to interpret the outcome temp of the relationship between Supply and Return temp?
2- Compression Ratio - How to interpret the compression ratio for troubleshooting a system?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 03-02-2011, 08:21 PM   #2
hillbilly guru
Send a message via Yahoo to hvacguytn615
delta temp if you had 72 degree return temp and a 53 degree supply temp you would have a 19 degree temp difference rule of thumb is 16 to 20 degree diff and system is working with in range the same for a furnace if you had 75 return and 125 supply air temp you have 50 degree temp rise the unit size and manufacture will set the range (i.e 35-70 ) but most tech use super heat and subcooling now its a must with t.x.v valves on most systems and as far as trouble shooting you should be abel to down load some empathy charts online the charts and the data from the system your working on should be all you need
hvacguytn615 is offline   Reply With Quote
The Following User Says Thank You to hvacguytn615 For This Useful Post:
JJboy (03-02-2011)
Old 03-02-2011, 09:08 PM   #3
Check out this expanded performance data on a Goodman JJ. For cooling the bottom line is the higher the moisture in the indoor air, the lower the delta T
http://www.cozyworld.ca/goodman-heat...-tech-info.PDF
Old 03-03-2011, 05:30 PM   #4
Ideally, the delta t should be taken at the unit, ie. supply plenum and return plenum.
If the supply air at the vent is > 2-4 degrees warmer than at the supply plenum, your picking up to much heat in the ducts.
Poppyloppy is offline   Reply With Quote
Old 03-03-2011, 06:18 PM   #5
JJboy's Avatar
Thanks Poppyloppy.
Does anyone have Compressor Performance Calculator program?
http://hvac-talk.com/vbb/showthread.php?t=56471
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
