I Have To - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 03:50 PM   #1
I have to
I have to thump the thermostast in order to get the heater to turn on. I can set my thermostast at 69 or 70& ect the heater don't come on
Last edited by Sue55; 12-04-2011 at 03:53 PM. Reason: Williams wall heather #35cv c 51 nat
Sue55 is offline   Reply With Quote
Old 12-04-2011, 07:43 PM   #2
An old Tradesmen
Rewards Points: 6,464
Made this its own thread, and moved it to the HVAC forum.
The Following User Says Thank You to beenthere For This Useful Post:
Sue55 (12-04-2011)
Old 12-04-2011, 08:24 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Could be dirty, could be a loose wire, could be low battery charge if digital or it simply could be on it's last leg.
Digital or analogue (old mercury) thermostat?
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Sue55 (12-04-2011)
Old 12-05-2011, 06:00 AM   #4
jkv
sounds like a analogue that got unbalanced. Need more info. Sue55
jkv is offline   Reply With Quote
The Following User Says Thank You to jkv For This Useful Post:
Sue55 (12-05-2011)
Old 12-05-2011, 10:27 AM   #5
Wall heater
Williams wall gas heater only no air Model #35cv c 51 nat.
Old 12-05-2011, 07:00 PM   #6
REP
Sounds like it may be a milivolt system.If so any loose connection,any uncleaned wires could cause your problem.It also could be a weak generator on the pilot,or an old snap action stat.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
Sue55 (12-05-2011)
Old 12-06-2011, 09:15 AM   #7
jkv
More than likely it will have an old snap action stat and needs a good cleaning
Old 12-06-2011, 09:26 AM   #8
biggles's Avatar
remove the stat and put the 2 wires together..if you get a solid burner then clean the stat contacts with a piece of sand paper emory board...pinch it in between the contacts and pull it thru them....lightly...
