Old 04-06-2007, 08:24 AM   #1
I get a 2-blink indicator
I have a 92.8 Efficiency Ruud Furnace
I am getting 2 Flashs then two secound wait indicator on the furnace and the igniter won't auto-start the furnace. I read the the the 2 flash code ment the the pressure switch is open. I beleave I have two pressure switchs. I pulled the hoses off of them both and tried blowing into the switchs, but nothing. I then tried sucking on the hoses but still nothing. I am still getting the 2 flash then 2 secound wait code.
I would be greatfull for any and all help.
Thanks for your time.
Glacieo
Glacieo is offline   Reply With Quote
Old 04-06-2007, 09:46 AM   #2
A blocked vent or intake can cause that fault, so can a condensate drain thats not draining. There is a VERY good chance that you ruined a exspensive switch by blowing and sucking on it.
Why do people do that? Now instead of a inexspense minor repair you need a exspensive part as well. Call the pro's and be happy!
harleyrider is offline   Reply With Quote
Old 04-06-2007, 10:46 AM   #3
I had two different so called "pros" (that I paid $150 to) come and look at my furnace a few months a go. When I was haveing a different problem. They both blow into the same hoses as I did while checking it out. After seeing them do it, while looking for what could be wrong with it last time and reading on the net about others doing it. I did the same, just to see if it would work. Any way is its still saying the pressure switchs is open.
If what you say is true then I guess the pros around here don't know what they are doing as well. There for I must really be in need of some help.
Thanks again for your time.
Glacieo
Old 04-06-2007, 11:06 AM   #4
I had been running it for a while now and we went to bed last night with it on and when we got up this morning it was not on. That is when I went down stairs and seen it had the code 2 flashing.
Old 04-06-2007, 03:51 PM   #5
Ok then........well I say you most likely need new switches, but also a underlying problem...........clean the condensate drains and lines.
Trane XE80 (Pressure Switch Indicator Err) cherande HVAC 7 09-25-2008 01:02 AM
Trailer Wiring No Blink But Hazards Jamn68j Electrical 1 05-22-2007 11:01 PM
