I Am Having Problems With My Fuel Oil Pool Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 09-05-2010, 09:08 PM   #1
I am having problems with my fuel oil pool heater
I am having problems with my fuel oil pool heater. Laars by Jandy. After bleeding water from the filter ,inlet line and pump I find that the fuel and water had emulsified in the pump. After freeing the pump of this I hit the reset button on the burner housing. (it was blinking at about 1 second intervals). Nothing happened and the system would not reset.
Do I need to replace this reset assy. It is a Beckett R7184A 1075?
fred Disk is offline   Reply With Quote
Old 09-06-2010, 05:24 AM   #2
An old Tradesmen
Rewards Points: 6,846
Nothing happened. As in it didn't make a sound, the motor didn't run, etc.
Or it ran, but you had no ignition.
Old 09-06-2010, 09:26 AM   #3
pool heater problem
Nothing happened when I pressed the reset button, No pump no ignition that I could hear, Nothing! And the blinking light continues to blink at the same frequency. I saw that a replacement assy. is almost $100.00 and I would like to know if replacement is the answer before I spend the $.
When I do get the heater operating I believe that I will have to install an inline fuel/water separator as I have had a water in the fuel problem before. Any advice would be appreciated. Fred
Old 09-06-2010, 10:02 AM   #4
An old Tradesmen
Its in safety lock out mode. Means it has tripped 3 times with no ignition.
It needs to be pushed in and held in for 45 seconds.
After you reset it. Don't push it constantly, if its not igniting.
Old 09-06-2010, 10:10 AM   #5
Been there, I will go out and try to hold the reset for the 45 seconds. I did hold it in for a while but perhaps not las long as you suggest. Thanks Fred.
post next to inground pool RJoe Building & Construction 1 08-01-2010 04:46 PM
Pool Site Excavation Question ProDIYer Building & Construction 0 07-07-2010 03:09 PM
toilet and hot water heater problems spokanern Plumbing 5 01-19-2010 01:41 PM
Electric Wiring for Pool Heater (heat pump) tazmajazz Electrical 7 10-21-2009 08:49 PM
Problems with Dayton 5UT20 hot water garage heater tcellis HVAC 3 03-17-2009 03:28 PM
