I Added A Radiator To My System And Now Need To Know How To Refill Enough Water - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-30-2008, 05:25 PM   #16
Union HVAC Tech.
You could open the bypass and bring it up to @20 psi on the gauge to make it easier to bleed.
bigMikeB is offline   Reply With Quote
Old 01-30-2008, 05:41 PM   #17
Hi Big Mike - Thanks for the assist on this. I believe the bypass you refer to is yellow lever in this pic. When opened I can hear waterfill. it is directly between the expansion tank abd the boiler . So when opening this I can watch the gauge reading change ? wipk http://i263.photobucket.com/albums/i...2/DSC04305.jpg
memovox2 is offline   Reply With Quote
Old 01-30-2008, 05:44 PM   #18
Union HVAC Tech.
Yes it the yellow handled ballvalve right over top of the extrol tank. Open it a little and stop at @20 psi, this should help you bleed out the air faster. Is your new radiator hot?
Old 01-30-2008, 05:49 PM   #19
Ok I have opened the yellow lever and YES the PSI went up to 20. Also, yes new radiator is hot and working great. No leaks. Now I can go an open and close bleeders and bleed out air right?
Old 01-30-2008, 06:10 PM   #20
Union HVAC Tech.
Yup, sure can.
Old 01-30-2008, 06:23 PM   #21
Does it matter if the system is on or off? I really REALLY appreciate your help on this!!!!!!!!!
Old 01-30-2008, 08:27 PM   #22
Also do all zones need to be on or off when filling. . .
Also do all zones need to be on or off when filling. . . I think this is gonna do it. . . . . Let me know if you have a chance. Thanks so much.
