Hydronic Radiant Flooring - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 03:31 PM   #1
Hi:
I'm pretty excited about the recent installation of my Triangle Tube Prestige Solo and considering all thin cool things I can do with the unit. I'd like to start using radiant floor heating in a couple places if possible. First, I'd like to put some type of flooring on top of the 7'x'12' tile floor on my front porch. The trick with this is finding the thinnest possible solution.
1)
What is the thinnest option available for hydronic radiant flooring? If there's something that has both the sub-floor/casing and the finished top floor, I'm certainly not opposed to using this (if it's available). If a combined under-layment + finish-floor option is not available, is there a minimum thickness thickness that's required?
(I'd like to not have to cut the doors and raise the door thresholds if it is avoidable.)
2)
Has anyone ever tried installing Hydronic radiant heat from BELOW the existing flooring... between the existing joists?
This is not something I'm really currently investigating, but it would be interesting to know if there's information out there on doing it. I'd love to change my radiators over to radiant floor heating, but I don't want to have to replace all my existing wood & tile flooring. I do however have exposed basement joists. What if it was possible to pin tubing to the basement ceiling, and then spray-foam below it all? Has anyone ever tried anything like that?
EDIT: I found my own answer to #2. Apparently this is pretty common practice. Good to know! Here's a guide by Radiantec: http://www.radiantec.com/pdf/Within_...diant_Heat.pdf
mknmike is online now   Reply With Quote
Old 08-06-2012, 02:02 PM   #2
Originally Posted by mknmike View Post
Hi:
1)
2)
Hey Mike,
I've just installed hydronic radiant on top of my subfloor, with hardwood floor on top. I chose 10mm thick strand woven bamboo, and together with the heating loops, everything is only marginally thicker than carpet+pad - at least in my case, there's no reason to cut or rehang doors.
It's a completely custom system with OSB cut into strips and the tubing runs in between. I've been posting about our experience in the hopes that it'll be helpful to some attempting a similar project:
http://pieschefamilyhomeimprovement.blogspot.com/
The 'diary' is still not complete (still sifting through pictures and organizing everything), but I'm updating frequently. Hope this contains some useful information for you!
Olaf
opiesche is offline   Reply With Quote
Waterfurnace Hydronic Water and Air Heatpump Thermostat Configuration JDForinger HVAC 8 12-05-2010 04:57 PM
Baseboard and Radiant Flooring Dilemmas Summiteer HVAC 4 03-13-2010 06:12 AM
Wanna help design a hydronic radiant heating system? YerDugliness Green Home Improvement 4 05-03-2009 10:10 AM
Hydronic heat and flooring Blondesense HVAC 2 11-24-2008 09:38 AM
Laminate in Basement over Hydronic Radiant Heat art2670 Flooring 3 10-12-2007 10:17 PM
