Hydronic Radiant Floor System With Potable Water Radiators - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 03:18 PM   #1
hydronic radiant floor system with potable water radiators
I have a radiant floor heating system using Radiantec supplied pex & pumps in 4 rooms (each is a zone with thermostat & pump) & the system also supplies our hot water. I had an old boiler steam system with radiators for the other rooms in the house. Boiler gave out so I would like to add some zones to the system but I don't want to rip up flooring (2nd floor rooms) & would like to use hot water radiators but they have to be 'potable' i.e. made of copper or stainless steel so the water is still drinkable after passing thru. Does anyone know where I can find a US manufacturer? When I google I find mfgs in Australia, the UK and China but nothing in the US.
thejaybird is offline   Reply With Quote
Old 11-09-2011, 04:38 PM   #2
Rewards Points: 1,538
deleted
Old 11-09-2011, 05:10 PM   #3
An old Tradesmen
Rewards Points: 7,816
You an use regular rads, if you use a flat plate heat exchanger.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
One Tankless Water Heater for Hydronic & Potable? VIPSpecialNeeds Plumbing 3 07-30-2009 03:09 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
