Hydronic Heat And Flooring - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2008, 12:07 PM   #1
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Hydronic heat and flooring
Some background.
Our house was built in 1972 with what I believe is called hydronic heat. Hot water pipes embedded in the slab foundation fueled by a propane boiler.
The torn up carpet is slowly working its way up our to-do list and I am researching alternatives.
I don't think any wood/engineered wood/laminate will hold up to our friends (the biggest one not shown) so it will be tile or carpet. With all of the brick and stone I'm currently leaning toward carpet (possibly a a glue down commercial) to soften the look.
My questions: Is there a significant difference in the efficiency of the heat going through tile vs carpet? And how much difference does pile or padding make?
Also, am I likely to encounter any problems between the adhesive and the heat if I go with a thinner glue down carpet.
Very few people around here even know what a hydronic system is. The HVAC people say ask the flooring people, and the flooring people say ask the HVAC people. Any advice or links would be appreciated.
Old 11-22-2008, 06:50 PM   #2
tk03's Avatar
Rewards Points: 150
The more thermal mass the better floor heat works. If you choose carpet, there is special padding, carpet and adheasive for radiant floor heat.
tk03 is offline   Reply With Quote
Old 11-24-2008, 10:38 AM   #3
Stuck in the 70's
Thanks for the info.
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 11:50 PM
All about flooring wooden floors (part 1) abraun Flooring 8 04-28-2008 11:46 AM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
Radiant Heat Flooring As Only Heat Source? digthisbigcrux Building & Construction 2 03-10-2007 12:33 PM
IAQ and flooring. Briefly. Benhamcarpetguy Flooring 12 03-24-2005 09:53 PM
