Hydronic Heat/air Handler Concern - HVAC - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 02:19 PM   #1
Hydronic heat/air handler concern
We had just purchased a vacation condo in Nevada. It has a Goodman Vertical Hydronic Heat Air Handler. My concern and question is because were rarely going to be there , can i turn off the main water to the condo and turn off the thermostate for 3 to 6 months at a time without doing any damage to the Hydronic heat handler? eg.Could water sitting in the unit for a long period of time seize up the pump? Any advice on this particular unit would be greatly appreciated. Thank You
duster is offline   Reply With Quote
Old 03-23-2010, 04:49 PM   #2
An old Tradesmen
Rewards Points: 7,370
Water stilling still for months generally won't seize the circ.
Here on the east coast. We don't drain or run our boilers over the summer.
Old 03-24-2010, 09:57 PM   #3
Can we presume that freezing temps will not be an issue here?
meboatermike is offline   Reply With Quote
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 05:52 AM
Space Pac Air Handler Wiring--208-230/60/1 Volts metal121 Electrical 4 05-05-2009 10:20 AM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
