Hydronic Forced Air - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 01:20 PM   #1
Hydronic Forced Air
Hi
I am looking to purchase a home and after the home inspection i found the house has these things in every room. From my search this looks like a hydronic Forced Air. Does anyone know anything about this ? is it eficient ? Any issues with the system as far as fire, water damage etc? what is the cost of changing this ?
any input is greatly appreciated.
thanks
kingloose is offline   Reply With Quote
Old 02-19-2013, 03:08 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by kingloose View Post
...and after the home inspection i found the house has these things in every room. ... any input is greatly appreciated.
Tell the seller to contact you after they have replaced the HVAC system completely. Meanwhile... keep looking for other houses.
eta:back out of the contract and get any deposit money back too.
Old 02-19-2013, 04:38 PM   #3
thank you for your response.
I am not sure the seller will convert of update the system. Iwanted to see if anyone here have seen this and cost of getting this converted to HVAC or any radiator system
thanks
Old 02-19-2013, 05:10 PM   #4
MarginallyQualified
It might take them a year to come to the realization...
--but if they want to sell-- then sellers need to fix their major systems.
The subtext of my first post is that very few buyers will have the many thousands of dollars needed to install a modern HVAC system (or new roof or whatever else that might be deficient in an older home) on top of all the other purchase expenses they have.
Most buyers will NEED the seller to do that level of work on their own and wrap the total cost into the negotiated price which will then be part of the mortgage. Serious sellers (with good agents) would have done it before listing and showing the home.
A good buyers agents would have already explained all this to you.
hth
Old 02-19-2013, 07:01 PM   #5
I appreciate your advice but what I am looking for is concrete fix. I am perfectly ok doing this work if the seller takes $$$ off the price. That said I am looking to see if anyone had seen this before, what kind of effort is required ? Options ? Etc
Old 02-19-2013, 07:06 PM   #6
DIY staff
Rewards Points: 7,174
What does the boiler look like?
Old 02-19-2013, 07:19 PM   #7
The boiler looks like its under 5 years old..
Old 02-19-2013, 07:23 PM   #8
DIY staff
We have a couple of long time boiler guys here that may be familiar with that vintage radiator system---
If the boiler is up to date, you just need to figure out if that radiator system is efficient and trouble free--
Be patient--it's cold and some of the best 'help' is likely working or eating supper----
Old 02-19-2013, 07:25 PM   #9
DIY staff
I like hydronic heat--I have it in this house----good efficient and trouble free--and cheaper that any other that I know of---
Old 02-19-2013, 07:35 PM   #10
This does look like a vintage system I have floated the pics to a local hvac shop and they were as intrigued with this system as I was
It seems there a lot of moving PArts and not much support out here to for this particular system. It is pretty loud as well
Old 02-19-2013, 07:52 PM   #11
DIY staff
I owned a building with a combination steam radiator / steam heated forced air system---that was unique---and required the service of the oldest boiler guy in the area----
for a home---converting to baseboards might be an option----the ducts could be used for air conditioning---
Do you have pictures of the heat exchanger?
Old 02-21-2013, 04:42 PM   #12
newtech's Avatar
Rewards Points: 164
Hi
thanks
Attachment 65964
Attachment 65965
Attachment 65966
I have seen quite a few of those.
There should be a t-stat for each fan coil. It was a way to control heat to each zone, instead of using zone valves with baseboard heat.
There should be no problems with a fire ( but you do have an electric blower motor ) as the water temp should be 180F max. As far as water damage goes... You could have that with any hydronic system.
newtech is offline   Reply With Quote
Old 02-21-2013, 05:01 PM   #13
newtech's Avatar
Rewards Points: 164
If they didn't oem the motors, most parts are generic.. A lot of contractors told the customer the same thing, I think that they just didn't know how it operated. It is just a simple fan coil unit.....
Old 02-21-2013, 08:09 PM   #14
Missouri Bound's Avatar
Get a picture of the boiler, and get a mfg. date. How are the units piped, pex or rigid? Get a HVAC in there to evaluate the equipment and give you a cost for replacement of the units, and the boiler if needed. Nothing is cheap. Where do you live....is air conditioning a consideration as well?
Do you want it your way or the right way?
Anyone convert their home from forced air to hydronic baseboard? Badfish740 HVAC 3 10-18-2011 10:31 PM
Hydronic Forced Hot Water Baseboard to "Radiator" Thunder Chicken HVAC 1 08-19-2011 09:02 PM
Waterfurnace Hydronic Water and Air Heatpump Thermostat Configuration JDForinger HVAC 8 12-05-2010 04:57 PM
One Tankless Water Heater for Hydronic & Potable? VIPSpecialNeeds Plumbing 3 07-30-2009 03:09 AM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
