Hydronic Expansion Tank - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 01:09 PM   #1
Joe F's Avatar
Rewards Points: 294
Hydronic expansion tank
I'm doing a bit of re-plumbing of my hot water baseboard heat system. The house was built in 1959. It has a relatively new Burnham boiler, but still the system still has the old 6 ft by about 14" (huge) expansion tank mounted in the overhead. I'm thinking of replacing it with a smaller (modern) tank while I have the system down. How do I properly size the new tank, and what are the rules for placement?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 09-06-2009, 02:34 PM   #2
JohnH1's Avatar
Try this link. http://www.amtrol.com/pdf/extrolbrochure.pdf
JohnH1 is offline   Reply With Quote
Old 09-06-2009, 06:17 PM   #3
Joe F's Avatar
Rewards Points: 294
Thanks John.
Old 09-06-2009, 06:30 PM   #4
JohnH1's Avatar
The new tanks do not pipe in the same as the old expantion tanks. Your tank may be set up for a air seporator to vent air back into. The old still tanks work fine. Are you having any problems with your system now? Why are you concedering changing.
Old 09-07-2009, 04:48 PM   #5
Joe F's Avatar
Rewards Points: 294
The old tank is very large and originally had a Taco Air Scoop that was plumbed into it. The plumber that installed my boiler in 2000 removed the air scoop and plumbed the tank directly to the system. My main reason for wanting to swap it out was that I figured it's a fairly inexpensive upgrade (get rid of the behemoth, better pressure control). I've got the system down so, "might as well" (you know how that goes)
Installing new expansion tank ted schumm HVAC 2 07-19-2009 09:49 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
how to install a expansion tank to a gas boiler iris Plumbing 2 10-08-2008 02:17 PM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 10:53 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
