Hydronic Baseboard Temp - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 08:27 AM   #1
Rewards Points: 37
Hydronic Baseboard temp
Due to a remodel I have a mix of 40 year old and 5 year old baseboard heaters in my house. The older baseboard does not seem to get as warm as the new. Is the newer style more efficient at dumping heat into the room? Should I consider replacing the old with the new style to keep the heat more even throughout the house?
nbmech is offline   Reply With Quote
Old 11-29-2010, 08:34 AM   #2
the Musigician
DangerMouse's Avatar
If your finances permit it, I'd do it.
There could be various reasons for the poor performance of the old heaters, (gunk built up, newer fin style works better, etc.) all of which might be taken care of this way.
DM
Old 11-29-2010, 05:49 PM   #3
An old Tradesmen
Rewards Points: 7,814
Could also be a water flow issue. And not related tot eh age of the heaters.
Old 11-29-2010, 07:18 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
the old baseboard may be plugged up with hair or other debris or may not have proper clearance between bottom of register and flooring
hvactech126 is offline   Reply With Quote
Good looking hydronic baseboard heating? Clutchcargo HVAC 9 11-06-2011 06:41 AM
Waterfurnace Hydronic Water and Air Heatpump Thermostat Configuration JDForinger HVAC 8 12-05-2010 04:57 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Hydronic Heating (hot water baseboard) Question Midicat HVAC 7 10-06-2009 05:27 AM
baseboard temp nbmech HVAC 4 11-11-2008 04:50 PM
